Best street setup
Old Jun 21, 2008 | 01:56 AM
C.B.2fst's Avatar
Default Best street setup
hey guys my dad has an 01 magnetic red 2 coupe, he wants to begin a build over time. we already have a vortex ram air with air bridge and borla stinger quads. he wants to have a 500-600hp street drivable car which is very reasonable. but he wants to go n/a and i'm trying to convince him to go s/c. what are your guys preferences for this much power? and i have also read that a stock ls1 block starts to have trouble after 500 hp is that true or was that guy a retard? any and all suggestions are welcome.
Old Jun 21, 2008 | 04:44 AM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com...Car.php?car=43
We built this C5 years ago and it is this years Sept car in the ProCharger calendar. It is still on the stock bottom end, no problems and it also has a head and cam package on it. Bob
Old Jun 21, 2008 | 09:14 AM
BlazinT/A's Avatar
slowhawk built a vette using a procharger p1sc at over 500 rwhp wityh a stock bottom end
Old Jun 21, 2008 | 09:32 AM
ProjecT 9's Avatar
check my sig. Completely streetable setup.
Old Jun 21, 2008 | 09:40 AM
Websy21's Avatar
I also say get a procharger kit, might as well get the D1 kit from the start and don't look back. No need for heads but might as well throw in a blower cam while you are at it. Definetly isn't needed though.
Old Jun 21, 2008 | 03:38 PM
C.B.2fst's Avatar
what about a kenne bell? i've heard good things about them but not many people use them why is that?
Old Jun 21, 2008 | 03:45 PM
C.B.2fst's Avatar
ok guys i've been shut down on the s/c aspect so if u could start givin me good n/a 500+whp heads and cam and intake setups i would greatly appreciate it.
for those of u wondering my dad says he likes the sound of n/a better and if he were gonna go s/c he would get a magnuson. i think he's retarded but it's his car
Old Jun 21, 2008 | 04:18 PM
jbusmc1986's Avatar
A heads and cam setup will bring you barely to 500 if spec'd properly. I actually am putting my setup that I never installed up for sale, should be around a 500 hp setup with a good intake. Pm me if interested.
Old Jun 21, 2008 | 05:36 PM
C.B.2fst's Avatar
ok to give yal an idea what my dad is thinkin he wants to go with MTI's X1 cam and LG street headers. alright lay it on me can we get 500 out of this?
Old Jun 21, 2008 | 06:49 PM
98Z28MASS's Avatar
No...you will need new heads (afr 205's come to mind), large cam similar to the g5x3/g5x4 or comprable, ported fast 90/90, pullies, long tubes, off road x-pipe, and catback of your choice. Probably need new injectors and better fuel pump too. Def need a spot on tune too. It can be done on a stock CI ls1 as there are guys on the board with 500 rwhp but its def not easy or cheap.
Old Jun 21, 2008 | 07:58 PM
C.B.2fst's Avatar
how bout the mti v1 cam, complete lg street headers back kit, afr 205's crane 1.8 rockers, fast 92mm intake and tb, kenne bell boost a pump, aeromotive fuel rail kit, venom 40lbs/h injectors, and tuning? would we need the pullies and if so what exactly do they do besides get rid of parasitic hp loss?
Old Jun 23, 2008 | 03:34 PM
98Z28MASS's Avatar
Do you have the specs on the V1 cam? I checked MTI's website real quick and didnt see it listed. Your probably going to need a cam in the mid 230's to maybe low 240's range in duration, so im not sure if thats what the V1 is. Everything else sounds pretty good and I would say def get the pullies as they are quite helpful on heads/cam setups, especially as your trying to approach the 500 rwhp HP mark. As you stated they basically free up parasitic HP loss by not allowing or inhibiting your accessories from pulling available power from the engine.
Here is someone with a similar setup to what you are looking at:
https://ls1tech.com/forums/showthrea...ghlight=v1+mti
pulled 460 rwhp, not too shabby and his mods are in his sig.
Here is a C5 setup with the V1 and Milled AFR 205's:
477 rwhp
With the mods your looking at you should be in the ballpark but might need a slightly bigger cam to hit the magical 500 rwhp mark. Also, not sure on what size primaries on the lg street headers but your going to want full longtubes so minimum 1 3/4 inch primaries or maybe even step it up to the 1 7/8 primary version.
Old Jun 23, 2008 | 07:10 PM
BlazinT/A's Avatar
dont forget clutch and other drive train mods, with that much power your looking for trouble
Old Jun 23, 2008 | 07:42 PM
TransAmcoupe98's Avatar
Well maybe you could talk him into Nitrous if he doesn't want FI. Alot cheaper and easier.
