comp 918's gonna be enough?
Old Jun 30, 2008 | 07:05 PM
FranCisco's Avatar
Default comp 918's gonna be enough?
Ok so I have the comp cams part #54-444-11 specs are 224/230 duration at .050 with the lift at .581/.588 all on a 114lsa. I plan on running about 7lbs of boost with this cam do guys think the 918's are gonna be enough spring with this cam and 7lbs of boost on top of it? all input appreciated.
Old Jun 30, 2008 | 07:24 PM
code4's Avatar
I would do a stouter spring. But I have seen people get by with 918's with low boost & low rpm's.
Old Jun 30, 2008 | 07:30 PM
FranCisco's Avatar
ya Im not spinning the motor that high just to 6k max.
Old Jun 30, 2008 | 07:41 PM
Floader's Avatar
I run 918's, I have 8 or 9 PSI and about the same cam specs, so far so good. better than a year and a half on em... kinda makes me feel bad , but hey it works
Old Jun 30, 2008 | 07:54 PM
FranCisco's Avatar
Why does it make you feel bad if it works use it right?
Old Jun 30, 2008 | 09:07 PM
AFASTYZFR1's Avatar
I had 918's...tr224.....spun it to 6300 w/ 10psi
Old Jul 1, 2008 | 02:25 AM
Johnv's Avatar
Hows the TR224 go with boost ? 112 or 114 lsa ?
I have a 112lsa tr224 from when i was NA, and was thinking of giveing it ago.
Old Jul 1, 2008 | 09:35 AM
AFASTYZFR1's Avatar
I think its a 112 lsa....it worked great
Old Jul 1, 2008 | 11:09 AM
Boosted 99 TA's Avatar
i have 918s runnin 5-6lbs, it runs great.
