single front mount
Old Jul 11, 2008 | 04:55 PM
93blacktransam's Avatar
Default single front mount
ok im doing single front mount turbo 77mm i believe ...do i need exhaust after the turbo down pipe or can i just put a dump on it where the normal y pipe would bolt on ...
and can someone post some vids of single front mounts with around 7 or 8 psi...iwanna hear this..
Old Jul 13, 2008 | 09:36 PM
ModularTurbo's Avatar
Dump it and spool harder!!!!!!
Old Jul 14, 2008 | 01:51 AM
fenix999's Avatar
Hey 93TransAm i already sent you a PM about your alternator bracket! Check it out and get back to me!!
***dumping it with no muffler will be pretty loud at around 2K rpms however the turbo will quiet it down ALOT at higher rpms, also performance with no muffler and the wastegate open to the atmosphere will be awesome!. It will have alittle rasp thing going on at 2,000rpm tho but who cares...So yea dump the wastegate to the atmosphere and just run whatever the downpipe size is straight thru all the way to the back of the car. For turbo size i wouldnt run any bigger than a 76mm for the street on a stock-ish 346 LS1, there is no need. If you want it to spool really fast and still make big power i'd go with a slightly smaller turbo. You'll get better response and still make whatever power you want to make (since you're limited to a stock motor im assuming) anyways ill get you a sound clip of what open wastegate and all that sounds like...gimme a sec
Old Jul 14, 2008 | 02:01 AM
fenix999's Avatar
http://youtube.com/watch?v=2Ce0n7Y5KIA&feature=related
and
http://www.youtube.com/watch?v=XNSpp6fKnLk&NR=1
BOTH cars are a couple guys here that are very cool guys with extremely fast cars as you can obviously tell. The first car is ??????'s here on ls1tech and the second white camaro belongs to a guy with a sweet twin turbo setup. His sig pic shows his engine bay shot with everything polished and two turbos. (edited) Its 02HUNTERSS car on here....anyways hope you enjoy! I love these two videos
Old Jul 14, 2008 | 02:10 AM
MUSTANGBRKR02's Avatar
that is 02HUNTERSS, Car is extremely clean in person.
Old Jul 14, 2008 | 02:13 AM
fenix999's Avatar
edited thanks, couldnt remember his name exactly. too many dam names, cars and setups to remember lol
Old Jul 14, 2008 | 11:36 AM
pozesd99''s Avatar
and
BOTH cars are a couple guys here that are very cool guys with extremely fast cars as you can obviously tell. If im not mistaken the first one is PUREVL's and the second white camaro belongs to a guy with a sweet twin turbo setup. His sig pic shows his engine bay shot with everything polished and two turbos. Its 02HUNTERSS car on here....anyways hope you enjoy! I love these two videos
the first vid is of nic d....
he is a tuner here in az and one of the best out there....
Old Jul 14, 2008 | 12:04 PM
fenix999's Avatar
sweet, that car sounds stupid fast
Old Jul 14, 2008 | 12:24 PM
pozesd99''s Avatar
on 16lbs he put low 800's down.... with a 76mm on a 346
Old Jul 14, 2008 | 01:07 PM
fenix999's Avatar
thats sick
