ANy downside to having the PCV system under boost?
Old Aug 25, 2003 | 11:28 PM
Mike00FRC's Avatar
Default ANy downside to having the PCV system under boost?
Quick question...
I know that ATI relocates the fresh air vent on the passenger side valve cover so that it does not see a boost condition, but what about the PCV? Could this be a potential problem, or is the valve only open under vacuum?
Thanks,
Old Aug 26, 2003 | 12:52 AM
y2khawk's Avatar
Default Re: ANy downside to having the PCV system under boost?
You should add a check valve between the stock PCV valve and the inlet to the manifold. Stock valve was never meant to hold close against boost.
Without the valve, you have potential to pressurize the crankcase. It won't hurt you to run the PCV system though.
Old Aug 26, 2003 | 02:33 AM
GoldenVelvet's Avatar
Just a side note; I had a Grand National and when the boost would come up (23psi) it would do two things, hall *** and push the dipstick up.
Old Aug 26, 2003 | 06:01 AM
smokinHawk's Avatar
Matt do you still have a pvc or an open breather system?
thought i saw you with an open breather.
Old Aug 26, 2003 | 07:22 AM
BudH's Avatar
Where did you get your checkvalve? Brand? Part number? Size? Etc?
Thanks
Old Aug 26, 2003 | 07:37 AM
Assassin's Avatar
do any of you guys run crank case evap. kits, for those who dont know, its where you weld a slotted fitting into the headers, and run a hose up to the crank case vent, and when the cars under power the exhaust accually sucks out the pressure
Old Aug 26, 2003 | 10:28 AM
smokinHawk's Avatar
i was looking into aftermarket crank case pumps liek the high HP race cars use.
Old Aug 27, 2003 | 10:43 AM
Mike00FRC's Avatar
Thanks,
I'll pick something up as a little added insurance.
