STS Firehawk Install Thread
Old Sep 13, 2008 | 10:43 PM
  #61
Blackbird's Avatar
agree the turbo is sitting pretty darn low. you should have it almost touching the heat shield. I would redo that part of the install. Looks like you need to cut the exhaust pipe and clock the whole thing and get it tucked up.
Old Sep 15, 2008 | 02:47 PM
  #62
Black_Hawk_02's Avatar
Yea... Its higher now. I added a hanger...
Old Sep 17, 2008 | 02:58 PM
  #63
Well i got my Wideband installed...
Im running about 12.7-12.8 at full throttle...
That stock...
NO BOOST
Old Sep 17, 2008 | 08:06 PM
  #64
needaz28's Avatar
how many psi? I take it you got the oil pump working right and your not leaking oil from the turbo anymore?
get that thing tuned and please let someone who knows how to use a eboost get that thing dialed in. you can get into alot of trouble quick on a stock tune with a eboost.
Old Sep 17, 2008 | 09:19 PM
  #65
i unhooked the turbo.
Old Sep 23, 2008 | 04:48 PM
  #66
Well ive been trying to figure out the problem with the oiling... so here is a link to that thread,
Thanks for all your help.
https://ls1tech.com/forums/showthrea...1#post10161771
Old Sep 25, 2008 | 09:43 PM
  #67
Well thank you for all your help... I hooked up all the oil lines.. and bolted the turbo up.. switched the wires... and fired it up... sure enough... everything worked as it should... the only problem im not sure how to hook up the PCV...
Thanks again everybody..
Old Sep 25, 2008 | 09:51 PM
  #68
needaz28's Avatar
does this mean your not mad anymore? retracking that I sold you a pile of **** and hooking me up with feedback on a 3k plus deal would be great.
I'm glad everything got worked out. if you haven't found the manual for the boost controller I found the file on my old laptop. pm me your email and I will send it over, and as I said before if you have any problems please call and I will help any way I can.
happy boosting
Old Sep 26, 2008 | 12:57 AM
  #69
Weird timing... I was just PMing you and leaving feedback.. but as i wasnt mad. just frustrated. i didnt mean to sound like an ***. i really am a nice guy.
Old Sep 26, 2008 | 12:58 PM
  #70
Well i had quite the scare today.. I was driving to the store. with some friends. and the oil return line. came off the was spitting oil on the manifold. i guess i didnt tighten down the cap... idk.. and i noticed the oil pressure drop (like 3psi) I find myself worrying about the smallest noices these days. Anyway... I pulled over and smoke started pouring out of the cracks in the hood. I was so scared. So i opened it and found the damn oil return line just hanging there... Damn... I guess i need to stick it in the oil pan.
Old Sep 26, 2008 | 06:41 PM
  #71
needaz28's Avatar
been there, done that, tapped the pan. lol
my engine bay is still a facking mess.
I tried to warn you .
Old Sep 26, 2008 | 10:08 PM
  #72
ehh. i cleaned it. Ill tap the pan.
but im out.. later guys
Old Oct 4, 2008 | 12:25 PM
  #73
Well, Ive spent the last few days. going through and cleaning every
thing up. Re-did all the piping.... made sure the t-bolts were tight.
Still need to finish hooking up the wastegate and the bov, and the
boost controller and gauge and then valve springs.
Im going to Mike Norris this wednesday for a tune.
Heard hes a great guy can't wait
Old Oct 6, 2008 | 11:55 PM
  #74
wow... i just read through this post... DAMN! i wanted this thing to be perfect the first time... now i just want it done... also sorry about the lack of pictures. i barely have time to work on it in a day... taking pictures is the last thing on my mind... I do have some pictures. ill throw them up here when i have some time.
Old Oct 6, 2008 | 11:56 PM
  #75
well i started my my valve springs sat night.. problems problems and more problems
s
so i went and finished them today. got to the last spring and one of the retainers was fucked up. it wasnt fully machined. so i couldnt use it...
so i put the stock one on, for now... and started it up and it cranked really slow but then started really quick and then idled at like 500 and didnt sound great... (broke one spark plug wire) and the valves were really noisy. so i shut it off. YELLED:#(&@!!!!! and then pulled the right side(where the noise was coming from apart and found 4 rockers really loose...(torqued to 22 but still moving... so i pulled them off, and out them back on and they seemed all good.. 22ft/lbs and they were nice and tight... so i bolted it all back together and started it... the valves were alot quieter and it sounded OK... so i let it run for a little bit and was gonna switch spots...go under a light(11:00PM-DARK) so i put her in gear and reved it up a little bit and there was this squeaky noise! I am so pissed and have no idea WTF is going on. so i shut it off and locked her up for the night!!! im suppose to get tuned on wednesday morning. this ruins my week. (on top of plenty more ****)!!!
whats happening?
Getting some help in the internals section too
__________________
Old Oct 7, 2008 | 12:49 PM
  #76
Tear... car took a **** today.
Umm. idk what happened.
I was driving... heard a "ting" and the car stalled... pulled over...
pulled off the right valve cover. (expecting to see pieces...) Everything looked fine. there were just some loose rockers...
Now i have to delay my tuning... What happened? How bad is it?
Old Oct 7, 2008 | 08:10 PM
  #77
Well i retorqued all the rockers to GM specs... 2 steps and all is good.
Still had to cancel my tuning with Mike Norris for tomorrow.
I need to finish all my vacum hoses. wastegate, BOV, boost gauge, boost controller.
Old Oct 7, 2008 | 10:28 PM
  #78
OUTLAWZ RACING's Avatar
Bro slow down and relook at everything and breath! Been down that road LOL! Hell I drop over 2k in a built six speed because I couldnt get it in third and guess what.... God dam pro 5.0 nut came loose that was it! They could not find anything wrong with my six speed after I tore it all apart so after I had it forge put it back in and bam was doing the same thing untill I look at the fkin shifter adjustment bolt was back all the way out!
Old Oct 8, 2008 | 02:30 AM
  #79
yea.... i was just getting too ansy. I just need to slow down... Which is why i pushed my tuning date back.
Also... I was driving it today... and the tune went to ****...
Cruising at like 20
Accel a little and it drops to 9
and then when i floor it its fine at 13-13.5
What is going on ????
Old Oct 8, 2008 | 08:48 AM
  #80
Thumbs up
Cruising at like 20
How clean is the maf? Oh and get rid of it buy a cobalt map ad speed density and you will love it even better. I was against it for awhile and I got fed up with cleaning that stupid maf and never look back. Car drives like stock minus the cam lope and turbo whine
