big 88 single + 402 99% complete pics!
Old Aug 25, 2008 | 08:37 PM
z28boysteve's Avatar
Default big 88 single + 402 99% complete pics!
Old Aug 25, 2008 | 09:19 PM
o2ws8's Avatar
looking good!How much power are you looking to get out of it?Or what are you aiming for?
Old Aug 25, 2008 | 09:50 PM
Well Originally was aiming for 1200flywheel, but the 3" downpipe screws me on that note, 900RWHP is probably what ill max out at before I run into backpressure issues. If It runs somewhere in the 9.50s or faster I can't really complain too much..... its a daily driver.
Old Aug 25, 2008 | 10:08 PM
o2ws8's Avatar
What kind of fuel system do you have??
Old Aug 25, 2008 | 10:29 PM
Sumped Steel tank, big weldon pump, #12 line to prefilter #10 to post filter and to regulator, weldon regulator #8 lines to each rail, #8 return, and 95#/hr injectors with an acceleronic impedance converter on the stock pcm
Old Aug 25, 2008 | 10:31 PM
71 chevy's Avatar
DAMN. 900hp daily driver.
Old Aug 26, 2008 | 10:13 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
That's pretty much the fuel system I have but I ditched my Weldon 2025 and went to two Bosch pumps because I couldn't take how loud the Weldon was. Looks like a cool setup!
Old Aug 26, 2008 | 11:33 AM
smokinHawk's Avatar
nice
how did you route the exhaust/up-pipes?
Old Aug 26, 2008 | 12:55 PM
For the most part, the Up pipes are all unmodified PTK pipes, with the exception that on the turbo merge collector/flange. the Wastegate pipe was cut off and replaced with a piece of 2" polished stainless to accomodate the TIAL 60 waste gate..
so the rundown is this.. shorty header on the pass. side, 1 5/8" primaries to a 2 1/2 inch crossover that runs behind the motor, and just behind the x member under the tranny and back up to the driver's side to merge with a forward facing shorty header and into the Turbo flange. the downpipe come out the turbo and back through the drivers side (It's cramped down there next to the block!) then Ive header wrapped all of it for a more durable trouble free setup.
Old Aug 26, 2008 | 01:34 PM
Broke EF's Avatar
So many bends on the cold side piping. Good luck with the build though, should be fun when you're all done.
Sean
Old Aug 26, 2008 | 03:43 PM
DeltaT's Avatar
Very nice, but can you get that air filter into some cool air somewhere?
Jim
Old Aug 26, 2008 | 04:11 PM
unfortunately, no, I have a 1 gallon water reservoir that I had sunk into the old stock battery location. it takes up all the space in front of the pass. tire
Old Aug 26, 2008 | 04:48 PM
TurboZ28408's Avatar
daaaaaaaaaamn
Old Aug 26, 2008 | 10:29 PM
obZidian's Avatar
looks good. wish i had gone with the 88 instead of the 85, but i think i'll be fine for now.
Old Aug 27, 2008 | 05:40 PM
anyone out there with similar combo and #s?
Old Aug 28, 2008 | 05:27 PM
Louis's Avatar
Im putting together something very similar, 415 cube LS3, single plane, PT88, 2 Tial 44s, 96#ers/Low Hz driver, Twin Bosch 420s in a 6 speed car.... No numbers yet, it runs all motor now, so it will be a complete documented build NA to boosted Hope to have the snail mounted this weekend and then hope for more time. May not be completely finished till after the Texas mile and the Petit Le Mans. I have a few cars Im preparing, so this gets the back burner.
Old Aug 28, 2008 | 06:13 PM
MUSTANGBRKR02's Avatar
That looks like a whole bunch of room in there. Looks good though!
