Any Superchargers W/boost controllers?
I am trying to see how much area under the curve you gain in the low boost mode that is what this thread is about and you'll notice even in low boost, even though hes making less peak power than you hes making more area under the curve still from 4k-5500rpm and I would assume the difference would be bigger under 4000 rpm as well.
Thats the reason we're looking at using a waste gate, to boost low and midrange and create more area under the curve overall.
Has anyone ever tried using a set-up that worked similar to a throttle body? If built correctly, an actuator or servo could drive the blade to offer more precision - variability, in releasing extra boost?
Would this work?
If this was discussed earlier please disregard this suggestion.
Would this work?
People always seem to bring up this idea in these threads.. and I think the biggest thing would just be the complexity of it. How would you control boost accuratly with it, and also what method would you use to actuate it?
use a boost actuated bypass between the restrictorplate and the supercharger.
Which allows more air between the plate and superchager untill a predetermined boostpressure closes the extra air intake
with that you can even use an in car boostcontroller, to dial in the amount of boost you want
Also, this means more load on the head unit...and more load on the belt. This by itself may be no big deal if your belt setup can handle the extra load, but you are also going to be spinning the head unit faster...to get the higher boost numbers at lower rpms. One would have to keep head unit redlines in mind.
Bleeding off boost should and does work...but wouldn't it cost less power to throttle the inlet side...before you have done the work of compressing and moving the air?
I agree, and the best method that I can see to do this would be with a variable clutch assembly on the blower that would allow the blower to be regulated to slow down. Obviously this would be very complex and expensive. Bob
http://www.procharger.com/racing-new...ng_may08.shtml
http://50mustangsuperfords.automotiv...ons/index.html
I would imagine that Jim Summers has tested them as he is very involved. Bob
Very nice links to race cars, but where are the cars even close to what we are driving/building, that show the street driven + race miles that we have proven with our setups... I'm sure Mr. Summers is a VERY respected racer, but these are street cars that we happen to race in this thread. And from many, many more miles of experience than he could ever accumulate with his race cars I can't find the negative in this setup from MY experiences... You know I respect what you say and contribute, but my experience on this topic shows no downside thus far... You must admit 761rw out of a little P1 isn't shabby... for me this is about boost by gear so I can get traction in the first 3 gears at the standing mile events... that's gigantic for my application... remember guys I'm at 30,000+ supercharged miles on this evolving setup, and the starting point was 620rw... so there is a slight amount of R&D on MY setup...
Taking shots at one of the most respected in the forced induction industry is pretty low. Bob was just trying to point out that Jim is not a NOBODY. Just because all the links talked about Jim's racing experience doesn't mean he doesn't have any 'street' experience. John Meany (creator of some of the most well-known aftermarket EFI systems out there, ie Big Stuff 3) was even quoted in a magazine article (forgive me, I don't remember the publication) saying that Jim was one of the best tuners in the country, street or strip.
Just because it's not on the internet doesn't mean that it hasn't been tried or tested by some of the industry leaders, whether it's Paxton, Vortech, ProCharger, or anybody else.
Kurt
What are you talking about dude... please read BEFORE you post... I have MUCHO respect for Bob and EPP... please don't imply something false, and it's O.K. to disagree, and it's also O.K. to agree to disagree... sooo get your facts strait before you accuse please... Thanks...
Maybe you should re-read. While Bob is very respectable in his own right, I was talking about Jim Summers!
Notice I repeatedly said 'Jim' in my post?
I PM'd NLR but havent heard anything back after about a week. I dont think he checks this board very often based on his post count
