Any Superchargers W/boost controllers?
i read that thread from the mustang forum and from the corvette forum and really got lost in the vette one. there were valid points from both threads. but still didnt break down how a restrictor plate can actually make the max boost sooner in the rpm range.
It would be handy to be able to know what size restrictor plate you need for different desired airflow though. I don't like the idea of guessing as it can get expensive to make several plates before you find the right size for your setup.
For instance I'm making ~13psi of boost with a 3.85" pulley on the D1SC. If I pulley down to a 3.4" pulley what size restrictor would I need to keep me from exceeding say 14psi max?
A restrictor will restrict the MAX airflow the supercharger will "inhale" but it makes more boost by pullying down to boost faster. this works cuz the engine requires less CFM to make X boost at lower RPM. So the restrictor is only big enough to restrict the super from makeing X cfm on the top end. Doesnt really effect it down low. Thus allowing you to pulley down and make boost sooner. Got it. my verbage may be alittle off, but i get it now.
Now to answer your question, i did read of someone making a throttle plate type deal that would swing up and down or side to side, with a set screw that would make it adjustable like a throttle body. so you could just move the blade open or closed to obtain your desired MAX boost. i think.....
http://www.youtube.com/watch?v=nAG1enBPwso
However... having a car with a big stall and a cetri SC is kiiiiiiinda like a turbo car... or roots style. Once ya nail it and the converter flashes your in boost all the time.
Id also like to figure a efficiency % on low vs high boost even though the impeller is at the same speed.
Someone needs to build a dang CVT transmission for these blowers lol.
My thoughts exactly. You could have a centrifugal with the response of a positive displacement without loosing the efficiency at all.
In fact, depending on how it was done, you could easaly gain efficiency.
Combine that with the boost by gear nature of whats being discussed in here and you suddenly have the exact boost you want at all times
But on a snow mobile, I would not be too surprised if the components for that particular function were about the foot print of a shoe box. So big, but not impossible. Just incredibly difficult and not really worth it
