LGM motorsports turbo hotside enquiry
To be honest, I don't think it is a viable business model. As everyone has said, there are to many variables. Just look at the OFI setup. The headers work fine with stock heads, but when you use ETP, All Pro, etc. heads with a thicker deck, the headers are not going to be in the same location and it causes problems. I have been reading about turbo builds on this forum for a long time, I've had two setups on my own car in fact, and there seem to be three main groups of people.
First there are people that want a complete kit down to every last nut, bolt, washer, zip tie, etc. and they want to keep every accessory, drive like stock, and so on. This group of people usually muster up enough to buy the kit and maybe a few supporting mods (fuel, motor, rear, etc), although a lot of times not even these are considered in planning. They want the world and don't want to pay for it. Look at the threads about the APS kit (a very nice kit, but not 100% perfect -- as if that is possible). These people are not going to invest in a set of headers or even a hot side because they don't have the facilities, knowledge, or paitence to build the rest of the setup.
Then there are people that build there own setups (or send them to someone to build). These people are sometimes more realalistic since they know they will have to do some cutting, welding, etc. to get the job done. However, even this crowd would be hesitant to spend the kind of money your quality headers would be worth, because if they can weld (required if building your own kit), they figure they can build the headers themselves or just use truck/C6/etc. manifolds and save even more money.
Then there are the people that send their cars to shops for a build. If the shop can fabricate a system, they can/should be able to fabricate headers, or again they will just use truck manifolds. If you have this shop build the headers for you, it will fit your car perfectly (at least in theory). This route isn't cheap, but you probably end up with a higher quality product in the end -- or at least a better fitting system.
Sorry for rambling, but that is the way I see it. I would love to see them made, but I don't see it working in the long run.
I would concentrate on a T-6 kit. Alot of Ls1's built as a turbo setup are usually going to max out most avalible T-4 setups. With the F-body being out of production, I just don't see it being a hot ticket item. Most people, like stated before, will just have a custom setup built around their car.
Chris
Chris
That is exactly what I was talking about. Everyone wants premium quality parts for ebay pricing. The next question that will come up is: Can we get a GP on them to take the price down even further!?
#32
Easy for you to say in PA! :-) Luckily, Lou is down here in Texas where you wouldn't dream of having a driver without A/C. Anyway, back to the subject...
I'd sure be interested in this. I'm contemplating a DIY turbo setup for my next project and definitely would buy stuff from you again, based on how happy I was with the headers.
Bring it on!
Bring it on!
#34
TT-TECH Veteran
Jeff Williams
#36
I see no reason for it to be over 2500-3k.
The headers will be the same for a T6 or T4 only thing will change will be the intermediate pipe, and you can switch later if you choose to do so. AC will be Kept, you will source your own rad/fan setup as well as turbo and intercooler. The Griffen rad seems to be popular, and sits upright which makes enough room. ABS will need to be relocated, which Im going to look into that further.
Things are in motion, I have talked to Jose at FI and I will iron out the details monday and get a mockup turbo or 3.
Im going to have 40 sets of tubes bent and assemble 20 sets. Working on the CAD drawings as we speak, so lead times will be short once we go into production.
I will keep you posted on how things look, but I will have 20 sets on the shelf before an order is placed
The rest of the kit will be in the hands of the consumer, that way you are in charge of your own destiny
#37
TECH Cry Baby BOSS APPROVED!
#38
As far as moving the abs... Just do the SJM abs delete.
Also have to have some sort of wastegate option, but im sure you already know that.
Thanks, Chris
#40
I can tell you it doesn't get TEXAS hot in PA! I think that is what he means is most of you guys don't have an 8 month summer, 1.5 months of fall and spring and 1 of winter lol, so anyone could get by for a few months of warm weather, but not down here. Whats up Louis?
Jeff Williams
Jeff Williams
