my new project/Nitrous or Magna
Old Sep 4, 2008 | 05:58 PM
vette_c6's Avatar
Default my new project/Nitrous or Magna
hey guys
got corvette z51 M6
Heads 59 CC 227 Valve 2.05
Camshaft Lift 650 650 Lope 11 ( custom ) ( not fitted )
Headers Long tube Borla X pipe and cutback ( planning to change to Zo6 cutback )
SLP underdrive Pulley ( not fitted yet )
FAST 92MM ( not fitted )
Piston -3.2 FLAT ( not Fitted )
Connector Roads 6125 ( not fitted )
i also got Direct Port ZEX WET SYSTEM
the question is
my engine Compressior will be 11.7
and i am planning to fit this stuff to shoot 100 to 200 Nitrous
but CAN i install the Heads, piston, connecting Roads and magna charger ?
i alread got one now Fitted in my Car
520 RWHP on Dyno Jet 510 RWTRQ ( on my stock engine )
if the compression goes to 11.7 will i brake my engine if i runned 5 psi on magna charger ?
and what HP should i expect ?
the other Question is
11.7 Compressior
Can i run Procharger ? or i have to change my heads to get Low piston Comp?
i will be waiting for replay guys
i am just waiting for the answer to start my new Project
Old Sep 4, 2008 | 10:57 PM
Pharm0r's Avatar
x2 on these questions, ive been wanting to run a 100 shot with magnacharger...
Old Sep 5, 2008 | 09:26 AM
98Z28MASS's Avatar
Depends on if you are going to use race gas or not. 11.7:1 compression is pretty high. FI and N20 can be run on high compression setups but you def need good fuel (not pump gas) to run those kinds of setups. I would say switch to a forged dished piston to lower compression to say 9.5:1. I think a magnachager on N20 would be a sick setup though!
Old Sep 5, 2008 | 12:13 PM
vette_c6's Avatar
then i guess i will remove the magna charger
and use Gas 93 octain
and see what will happen
and i guess i will shoot Nitrous
Old Sep 5, 2008 | 12:49 PM
venom ws7's Avatar
Nitrous with magnacharger is a lot for stock bottomend with 59cc heads.
Old Sep 5, 2008 | 03:32 PM
98Z28MASS's Avatar
With the nitrous I would make sure you have enough fuel and a real good tune, especially if your going to use a 200 shot. If you already have the maggie why take it off if you dont mind me asking? Id just lower the compression if I were you but that JMO.
Old Sep 5, 2008 | 08:44 PM
Pharm0r's Avatar
I think with a lower compression and good tune you could run the maggie with pump gas, and you can run a wetshot with a stand alone (higher octane)
Old Sep 6, 2008 | 10:50 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
http://www.performancetrucks.net/for...hlight=NXRICKY if you have 3/8" to raise the unit up.
Old Sep 6, 2008 | 05:13 PM
vette_c6's Avatar
well someone called me to buy my magnacharger with all the kit
and i know with magna 112 i cant go for High boost
i am running 3.1 pulley and getting 5 psi only
which is with 2.75 pulley i will get 6 Psi to 7 ( MAX )
thats why i wanna remove it
i already bought piston -3.2
connector roads and heads 59
to get high compressior and shoot Nitrous
my system is ZEX direct port WET
already bought FAST 92MM
so why not trying nitrous
and if i didnt like the car ,, i will change my HEADS from 59 to 72 or 68
and get Procharger
i will let you know guys how much i will make in Dyno JEt N/A
and also with Nitrous
thanks for the answers
Old Sep 7, 2008 | 11:53 AM
98Z28MASS's Avatar
and get Procharger
Thanks cool its whatever you want to do. The maggie can push over 500 rwhp but if you want to give N20 a try go for it! Ive been in both FI cars and N20 powered vehicles and its def a different feel. Lets us know how it goes!
