What kind of trans for 800hp dd?
Old Sep 16, 2008 | 04:25 AM
  #41
pozesd99''s Avatar
i have a 4l80e... you can go th400 or
Old Sep 16, 2008 | 05:47 AM
  #42
-Freak-'s Avatar
Originally Posted by transam69230
I have heard bad things about performabuilt trannies, i have a buddy that is running one in his procharged gto and he keeps destroying them. Call FLT great guys and the know how to build either the 60e or the 80e. You need a 80e for sure though!
I don't suppose your buddy's name is Tim and he runs a light blue colored GTO?
If so, last I heard he got so fed up with swapping trannies he parted the car out and will be looking for a vette and more then likely an APS kit.
Old Sep 16, 2008 | 08:02 AM
  #43
SPRAYED 01's Avatar
Wow you can do 180mph in your a4 T/a? Thats amazing.
Old Sep 16, 2008 | 10:13 AM
  #44
Silver_TransAm's Avatar
Thats what I said. I hit 6000rpms in overdrive. I did a mph calculator to figure out the speed since the gauge only goes to 155. But thats as fast as I can go with the 3.42s.
Old Sep 30, 2008 | 06:05 AM
  #45
jbusmc1986's Avatar
4l80e dumdumdum... then you will be all set with tranny's at whatever power you are going to make, I am not sure about for cars but for trucks doing the swap you can get a pi torque converter that still works with the 4l60 flexplate and the 4l80 trans.
Old Sep 30, 2008 | 08:33 AM
  #46
I found one finally with all conversion pieces minus crossmember and yoke/u-joint conversion kit. Feel better now that the car will be up and running in a week or so.
Old Sep 30, 2008 | 08:51 AM
  #47
Mike101's Avatar
I think its speedtech or speartech has a harness
Old Sep 30, 2008 | 09:03 AM
  #48
Just got off the phone with them. The trans I am buying has the barrel plug adapter but I dont think it has the vss adapter thing. I need to check so I do not buy something thats included with the trans.
Also will the stock torque arm wrk with the relocation crossmember from yank? I need to use the stock arm for now, but if I have to buy a torque arm now I guess I will.
