D1SC Install help!!!
Old Sep 15, 2008 | 11:19 AM
SCREAMIN01SS's Avatar
Default D1SC Install help!!!
Im in the middle of installing a D1SC on my 2001 camaro ss. I ordered the complete from EPP and Im at the part where it tells you to install the inline fuel pump and new hose with the t-fitting. I noticed my kit did not come with one. I installed the walbro intank fruel pump and injectors that come with the kit. Am I missing a piece or does the kit not come with the fuel pump they are talking about in the ATI manual because of the injectors and Walbro fuel pump Bob sends!!!!
Old Sep 15, 2008 | 11:22 AM
AFASTYZFR1's Avatar
All your need is bigger injectors and a walbro 255 unless you are going for more than 550rwhp
Old Sep 15, 2008 | 11:23 AM
'Trust''s Avatar
The inline pump is if you have a stock intank pump, however why not do 2 walbro's in the tank anyway?
Old Sep 15, 2008 | 11:25 AM
Thanks for the fast reply guys!!!! I was just making sure I was not missing these parts. So just to clarify, Since I installed the walbro intank fuel pump and bigger injectors, I do not need the fuel pump the ATI manuel is talking about?
Old Sep 15, 2008 | 11:59 AM
99ssleeper's Avatar
Correct.
Old Sep 15, 2008 | 02:35 PM
02NBMFormula's Avatar
correct, dont feel bad, i wondered the same thing when i was doing my install. enjoy your new found power!!
Old Sep 15, 2008 | 05:34 PM
99BlownSS's Avatar
I had the same problem.I think they should update their manuals!!!!I talked to them and they said that was in their kits now they dont use them.
Old Sep 16, 2008 | 04:39 AM
EPP's Avatar
EPP
The inline fuel pump that is mentioned in the ProCharger manual is what comes with their complete P-1SC kits. A D-1SC through ProCharger is not offered with a fuel pump as a standard item. Bob
Old Sep 16, 2008 | 08:42 AM
Thanks for the help guys!!!! I think the D1SC kit should also come with longer blower pully bolts and have the sumper damper drilled but if eveerything was already sone for me---- What fun would that be!!! lol I'm just about complete with the kit and then all I have left is the gauges and and wait for my computer to return from EPP. I keep you posted and thanks again!!!
Old Sep 16, 2008 | 06:19 PM
EPP's Avatar
EPP
The ATI Performance Products balancer use to come pre-drilled, but they quit doing that last year. I guess they wanted everybody to have a little more to do. Bob
