Fuel System Problems - Please Help
Old Oct 10, 2008 | 08:32 PM
LS1Camaro320's Avatar
Question Fuel System Problems - Please Help
I have a 94 Z28 and I have had some fuel system problems lately. I will go out to my car and try to start it, and sometimes it won't start. It has happened to me 3 times. I think that the fuel pump is going out because when it doesn't start, the fuel pressure gauge will show 0. Today I got it started by hitting the fuel pump a couple of times, but the fuel pressure was still only about 25 psi. So I think I am going to buy a new fuel pump, but I would like to hear from other people before I do. Which leads me to my next question. Will a stock fuel pump work or should I buy a walbro instead with the mods my car has which are listed below.
- Comp 305 cam
- Ported head and intake
- Roller rockers 1.7 ratio
- K&N CAI
- Pacesetter mids and y-pipe
- Flowmaster one-chamber
- 28.8 LS1 injectors
- Aeromotive AFPR
- TB Airfoil
- Mad Z28 Tune
I don't have any horsepower numbers on it because I have never had it dynoed.
Old Oct 10, 2008 | 08:34 PM
Also the fuel gauge doesn't work right if that matters any.
Old Oct 11, 2008 | 12:03 AM
FICINJECTORS's Avatar
I would go with an aftermarket pump. The price difference isn't much for the benefits, especially with your mods. also the injectors are only 28lbs at 60psi fuel prssure. if you are running 43.5 they are 23.5lbs.. is your tune set to 28lb injectors?
Old Oct 11, 2008 | 10:36 AM
The previous owner was the one who installed the injectors. The fuel pressure is set at the stock lt1 pressure right now. What if I were to turn the pressure up to 60 psi? Would the injectors then be 28 lbs again. Also I don't know what the tuner set the injectors at, I told him that they were LS1 28.8 injectors.
Old Oct 11, 2008 | 11:41 AM
if you have the tune at 28lbs and the rail pressure at 43.5 the ls1 injector only flows 23.5lbs.. Common mistake made today. run to 60psi if you can. I do not think a stock pump will last running that much pressure. Get a new aftermarket pump from racetronix.
Old Oct 13, 2008 | 07:06 PM
I pulled the pump assembly out today, and what I saw was a walbro pump with no bucket on it. Now correct me if I am wrong but LT1 cars are supposed to have the bucket like the newer cars correct? If ths is the case, it could be the reason why the car would die/not start when I was low on gas.
Should I just leave it the way it is and always keep atleast half a tank in it or put a bucket back on it?
Old Oct 13, 2008 | 07:19 PM
lifeisgood's Avatar
the bucket your speaking of doesnt work w the walbro intank
Old Oct 13, 2008 | 07:26 PM
Alright so I should just leave it how it is and not worry about it?
Do you have any clue why the fuel gauge does not work properly?
