fuel pump failing every 3 months
Where did you get the rail mounted pressure gauge? The only one I have found so far is at Autozone for $45, but it has a hose and when you plug it in, it pours fuel onto the ground. I think that will solve the problem
LOL... You can get one for ~50 bucks from one of the vendors >>>>> Just take out shrader valve out on driver side rail and screw on the adapter then srcew in the guage to that.
My TA has the Nasty Performance rails, I put the guage on the passenger side by the adjustable regulator I put in.
How low do you let the tank get before filling it up? If you are going under 1/4 tank then you are letting the pump sit up out of the fuel. This could cause it to over heat and fail
she goes 200 miles between fillups. Never anymore. I filled it up and we had to squeeze every last drop to get 10.09 gallons in. I think its a 13.5 gal tank? 98s are different. Ok I will look into the gauge! Thanks for info.
