What injectors should I buy?
I have a basicly stock 2002 ls1 in a camaro ss. I am adding PRC stage 2.5 5.3 heads, torquer v.3 cam, Fast 92/92 intake and throttle body. What injectors should I buy to upgrade from stock? I know most people with H/C/I go with the FMS 30lb injectors. Will these be enough or will they be close to being maxed out? Whats the next step up from these? I would guess FMS 42Lb injectors? Or is there something in between? I know the 30lb injectors end up being like 36 with the ls1 fuel pressure. What about the 42s?
well stock injectors for your car are the 28.8lb injectors rated at 43.5psi, which means they are 33.25lb/hr at our fuel pressure of 58psi.
The 30lb/hr which I'm guessing are rated at 43.5psi as most are, would be just a tad bigger, you can calculate the difference by simple doing so (percent difference)
30lb @ 43.5psi would be 34.64lb/hr @ 58psi
Now, what I would sudjest doing would be buying soem 37lb racetronix injectors (lucas/delphi) or any injector you want even RCENG (see my fuel and injector sticky) that is rated above 32lb/hr as that will leave you plenty of head room.
I would also sudjest u upgrade your fuel pump to a 255L/h such as the racetronix PnP kit they have. I have it and love it, you MUST use their wiring harness and it is pretty straight forward. Dropping the tank is not a big deal, I have done it 2 times on my car and several other cars, so people complaining about it can quit.
We can custom make you the Bosch Design III injector in any size you like between 30lb and 42lb for for $239 for the set of 8. Flow matched, viton o-rings installed, and a 3 year no questions warranty.
The factory pcm, has them listed around 28.8 for flow rate, which should be at the running pressure, not the normal 3 bar pressure that most are rated at.
Ryan
You'll be fine with the stock fuel pump as long as you stay N/A with this set up. Also, take a look at the Lucas 42lb injectors, I use them all the time and we have them on sale for $289, and $329 for a flowmatched set, plenty in stock.
I would go with at least 36 lb but probably no more than 42. If you are staying NA and that's it then 36 should be fine but 42 will leave you a little more to play with should your plans change a little down the road.
FICINJECTORS, is that discount code you listed in your sig ls1teck or ls1tech?
Or if you wish you can PM me your paypal address and I can send an invoice, or PM/email/call with credit card info. Or order from the site, its all up to you hehe.
