42lb injectors
42lb injectors
have been looking at the ractronix flowmatched set for 360, but it's a bit spendy. Not really tech savvy by any means, but what is the difference in flowmatched sets and non flowmatched. I've seen people just have their stock ones reflowed and matched at local shops? Any pointers?
I have a set of stock ones i would like to have you guys make into 42's for me. Especially for $200. How long is the turn around time and what is the best way to get into contact with you. Thanks
http://www.fuelinjectorconnection.co...order_form.pdf
For you I would strongly recommend our Bosch design III's, we have them from 19lb to 48lb and ranging from $189 to $239 for flow matched sets, with viton o-rings installed, and a 3 year warranty.
If you have aftermarket injectors already, we will have to discuss it further.
We take yours, rebuild them up to whatever size you like, flow match, fully rebuild, and include new o-rings and warranty them for 3 years.
Rebuilding your stock injectors like this makes tuning as simple as changing the IFR to the new flow rate, then adjusting for cam etc. They couldn't be easier.
Same as above
~Rich
Jon must not have noticed your car. On the 96's those are Multec injectors, which in all honesty are junk (we deal with them every day, I have an LT4 vette as well)
Same as above
~Rich
Same as above
~Rich
~Rich
~Rich
When going a large jump like to a 42 @ 3 there will of course be some tweking needed. As well you will have to tune for the mods as well.
Sorry if I was kinda generalized there.
sdotlog, the ones with the stripe are Bosch EV14, or Design IV, those are LS2,3 style.
http://fuelinjectorconnection.com/sh...&productId=179
If you order from the site be sure to use the code ls1teck for $5 off shipping.
