what size line is everyone using for the crossover?
Old Oct 15, 2009 | 06:49 PM
Taubr Unit's Avatar
Default what size line is everyone using for the crossover?
-couldnt find it under search-
What size line is everyone using for there crossover line? -6 or -8? Gonna order fitting real soon n trying to see what sizes to buy.
Old Oct 15, 2009 | 06:50 PM
streetassasin's Avatar
mines a -6
Old Oct 15, 2009 | 07:22 PM
02 z/28's Avatar
I run -8
Old Oct 15, 2009 | 07:39 PM
Taubr Unit's Avatar
well finally found stuff out. The fuel rails are 3/8 NTP with is equal to -6. So to keep it all the same size n keep flowing smooth ill run -6. FWIW, -8 is equal to 1/2in Figured it out n a little tech info here for anyone else wondering.
Old Oct 21, 2009 | 07:04 AM
JL ws-6's Avatar
Race your car!
I'd run a -8 to a Y, and run a -8 to one end of each rail and a -6 to the regulator... that way there's no question on wether you have enough flow or not.
Old Oct 22, 2009 | 02:54 AM
KrisXpc's Avatar
+1 on this..
I read about alot of guys running a series style fuel setup with a -8 feed and -6 fitting on the crossover in the rail.. Thats just asking for problems if you ask me..
Old Oct 22, 2009 | 01:59 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
I always prefer to run a -8 crossover so it does not represent a restriction to the second rail in series.
Nothing wrong with running fuel rails in series if done properly. I have quite a few customers with over 1000rwhp using this setup.
Old Oct 22, 2009 | 02:09 PM
JL ws-6's Avatar
Race your car!
You can run them in series yes, but if you're spending the $, the difference is probably less then 100 bucks to put a Y on it and run them in parallell, and with the rails in parallel the pressure from one injector to the next will be more consistant yes?
Old Oct 22, 2009 | 06:15 PM
KrisXpc's Avatar
Exactly!
Old Oct 22, 2009 | 08:48 PM
LS1TECH Sponsor
You are correct, but in theory only. There is always something better, but it comes down to if it is really necessary.... Just as a -10 line or 1" diameter rails could be better, they are not really necessary for something under approx 1500hp.
Based on over 5 years of building custom fuel systems, personally I would spend $100 elsewhere.
consider only half the fuel consumed flows through the crossover. The pressure drop in a foot of hose & a few fittings is negligible considering the flow capacity of a -8 lne vs. what fuel 4 cylinders can consume.
The complexity of mounting y-blocks & extra cost deters most.
Just my opinion & not worth arguing over, but spend your cash wisely.
Old Oct 22, 2009 | 10:03 PM
Taubr Unit's Avatar
well already got it set-up. Got a -6 crossover and gonna run it in series n save some money. Not gonna get anywhere near 1000hp, **** id be happy with 700hp. So to make it simple on myself i went that route. I stand by my decision, lol.
Old Oct 23, 2009 | 02:01 AM
uphigh07's Avatar
sounds good that -6 will be fine for what your doing
