Fuel PSI @ WOT?
Old Dec 9, 2003 | 09:57 PM
SmaknaSS's Avatar
Default Fuel PSI @ WOT?
I just installed an Autometer fuel PSI gage on my M6 01 SS. My fuel rail PSI with normal driving is 60 PSI but it goes to 54 PSI at WOT, I thought my WOT PSI is not suppose to fall below 55 PSI. How low does my fuel rail PSI pressure have to go before It's too low? I have a cam, headers W/ all the bolt on's making a little over 400 HP to the wheels N/A so I thought I should still be safe on a stock fuel set up. With the slightly low (what I believe to be low) fuel PSI Is that an indication that I should start looking into upgrading my fuel pump already with only 400 HP to the wheels? Thanx in advance.
Old Dec 10, 2003 | 09:24 PM
SmaknaSS's Avatar
Come on guys, someone's got to know.
Old Dec 11, 2003 | 02:43 PM
Colonel's Avatar
That's not at all unusual. Get worried if your FP drops below 50 PSI or especially if you note that you find that you're running lean.
I actually used to run 500 RWHP+ at less than 50 psi (about 45 as I recall.) I was able to adjust so that it wasn't running lean but to do this I hade to run my bank 1 side run richer than my bank 2 (the first rail was getting the fuel first and thus was seeing a little better FP.) I upgraded my fuel supply to bring the pressure back up to around 55 psi and that took care of the B1/B2 discrepency.
Old Dec 11, 2003 | 07:42 PM
SmaknaSS's Avatar
Thanx for the reply colonel. I guess I'll replace the fuel system when I get nitrous on the car just to be safe.
Old Dec 12, 2003 | 08:46 PM
JoSeY's Avatar
try just replacing ur filter 1st....quick and easy. My WOT is 65psi on stock pump and all....
Old Dec 15, 2003 | 11:03 PM
SmaknaSS's Avatar
65PSI, Wow, thats pretty good but I dont think It's the filter due to the fact that I only have 16K miles on the car and I use cheveron gas w/techron. Maybe If It's not too expensive I can just replace it anyway.
Old Dec 16, 2003 | 10:10 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
54 psi sounds okay, I would see 58 at idle and about 55 psi at idle.
I had one pump that was 35 at WOT that was no good.
Old Dec 16, 2003 | 10:38 PM
SmaknaSS's Avatar
Thanx for the reply, I'm not too woried about it now, I think I have a good idea now what is bad,moderate,and good fuel pressure from doing a search and reading colonel's and other knowlegable peoples past post.
