Best position for adjustable regulator
Old Nov 27, 2009 | 11:30 PM
396375's Avatar
Default Best position for adjustable regulator
I talked to a mechanic today who told me they moved the regulator from the end of the fuel rail to the fender well on their race car and picked up 2 psi.He said it was a bad idea to put the regulator on the end of the fuel rail and yet I see a lot of fast cars running them this way.I'm not sure I believe him.Any thoughts?
Old Nov 28, 2009 | 09:02 AM
Lonnies Performance's Avatar
LS1TECH Sponsor
If installed properly, it makes absolutely no difference if it is on the rail or 2 ft away.
Old Geezer's Avatar
I've not seen such a "phenom". However, I have seen regs screwed directly into the end of a rail, that developed cracks. I don't think hanging the wt of the reg, and hoses on a fitting, is a good idea.
Old Nov 28, 2009 | 04:19 PM
396375's Avatar
Thanks guys.Hey Geeser.Maybe you and I ran sometime at Bowling Green.The GNs were so simple compared to the C5s.Love them both though.I think if you have a steel bulk head fitting welded to the rail it should hold up.
Old Nov 28, 2009 | 07:19 PM
LS1TECH Sponsor
Mounting the reg to the rail is a neat way to do it, but you should always put some sort of brace to the intake for support.
Old Nov 28, 2009 | 08:36 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I'd also be leary of mounting the regulator on the rail itself - they don't weigh much, but couple it with engine vibration and it could eventually cause problems. That's why I mounted mine here:
It ended up working out well for me in my application.
Old Nov 28, 2009 | 09:54 PM
396375's Avatar
Geez.That crossover line looks like a -12.It must take 10 minutes to fill that thing up
Old Nov 28, 2009 | 10:21 PM
MeentSS02's Avatar
Nah...just a -8AN line for the crossover. The feed still uses the stock hard lines, so that limits me on that one, but the line going into it from the back is a -8, and the line feeding the rails is also -8. I use -6 for the return, which you should be able to easily pick out from the picture.
