Racetronics with out the hotwire kit?
Old Jan 13, 2010 | 03:21 PM
RsSean's Avatar
Default Racetronics with out the hotwire kit?
Is that possible to do, to run the racetronics fuel pump with out doing the hotwire kit. Forsome reason in my mind it is telling me not to do it.
Anydown side to not using the hotwore kit?
Old Jan 13, 2010 | 03:24 PM
Detroitmuscle's Avatar
sure its possible, but I would recommend the hotwire kit hands down. A more powerful pump requires thicker gauge wire, there have been several people on this site that have had problems by skimping out on the hotwire kit to later on buy it. Do it right, it shouldn't be an option to buy it without.
Old Jan 13, 2010 | 03:28 PM
01 Trans-Am WS6's Avatar
I just put my new Racetronix unit in yesterday without a hotwire kit and its fine so far. Knock on wood.
Old Jan 13, 2010 | 04:14 PM
koolaid_kid's Avatar
You would be better off doing the hotwire kit w/o the pump. The current draw of any pump is too much for the stock wiring, much less the higher draw of the aftermarket pump.
Your mind is silly cheap, do it right the first time.
Old Jan 13, 2010 | 04:36 PM
Nasty N8's Avatar
As said the wireing just is not sufficent for the added draw. I have seen connectors burn and pumps fried from not using it. I agree it should not be an option without it. Super easy to install.
Old Jan 13, 2010 | 05:06 PM
quews6lime's Avatar
get the hot wire kit ....
Old Jan 13, 2010 | 06:37 PM
Zero4488's Avatar
Restricted User
I did the pump and hot wire kit and I'm never looking back...
Old Jan 14, 2010 | 02:10 PM
RsSean's Avatar
Well i do have both already at the house. After talking with Mike from the WS6store he said it takes 15 minutes and click click and a screw and a nut and it is done so just do it. So i guess it was just my mind messing with me. Thank you guys for your feed back
Old Jan 14, 2010 | 02:56 PM
MadIceV8's Avatar
Customizing Director
For how easy it is to install the harness... no reason why no to.
Old Jan 18, 2010 | 11:19 PM
spaz1's Avatar
If you don't want to do the hotwire kit at least replace the wire with a thicker wire to the fuel pump.
Old Jan 23, 2010 | 11:45 AM
jerflash's Avatar
i have had the racetronics pump and hot wire kit for 4 years...works awesome
Old Jan 23, 2010 | 04:49 PM
ZL1Killa's Avatar
the contacts/connectors cannot take the current draw of the pump. I highly recommend the wiring kit from experience
