Injector size for 88mm turbo
Going with a pt88 turbo starting to part everything together. what size injectors for at least 13lbs of boost.
Injector combo with rails and what fuel pump/pumps are yall running, was looking at goin with a double or triple walbro setup similar to mity mouse.
i was running some 42's on 12psi at about 80% duty cycle i think i was about 60-65psi worth of fuel pressure.
now have 96's so i can run more boost.
engine is a 347 and of coarse the PTE88.
dual intake walbros when the second one would come on at 5psi
8an feed, boost regulated FPR (i think the base pressure was around 50psi)
Do they sell a bigger injector for a stock PCM? I have a LQ4 that i plan to add a 78mm turbo to, but i plan to use Alky to help with the fuel. It's a 2002(PCM). What size inject do i have now, how can i tell?
88mm on a 347 tells me that 83lb injectors would work with a decent amount of fuel pressure. Otherwise you could use 96lb injectors with a driver box if you wanted to run lower fuel pressure.
