Dual Walbro pump wiring question(s) with Racetronix harness?
I have a 2002 C5 corvette and will be putting in a dual walbro setup this week using the stock fuel hat. I already have the Racetronix harness installed on the car for its current fuel setup.
I am wondering if I can just plug the dual pump setup exactly like it is now with the single pump and not have any wiring issues? ie. Will the Racetronix harness help to not over-draw the factory wiring?
You can use two hotwire kits or DIY for pennies on the dollar
This diagram uses stock PCM fuel control with the second pump being engaged by a Hobbs switch for boosted apps. The hobbs switch can be replaced with a window switch for non FI setups
The main idea for hotwire kits are to keep the wiring independent and send as much current from the battery to the pump as possible. This keeps the feeds/outputs/grounds independent while grouping the low current relay control
Pocket, thanks a lot for the diagram. I am already using one hotwire harness so thats good.
Question: I really dont have to tap into the PCM, per say, do I? Wouldn't it be the same if I tap into the green wire back by the fuel pump in the factory harness?
