a1000 pump problems?
Old Jun 8, 2010 | 04:09 PM
purplepeopleeater's Avatar
Default a1000 pump problems?
so i have a 1994 trans am gt with an a1000 fuel pump on it with the aeromotive pump speed controller
so the car will run real strong for about 45 minutes to an hour then will just die and wont start for about a half hour maybe less but i cant figure out why this is happeneing even after i put the controller on it can anyone help figure it out
Old Jun 8, 2010 | 05:55 PM
Sweet71's Avatar
Did you change the pump when you added the controller? Pump could have been damaged from heat prior to adding the controller. Also I know aeromotive had a few pump problems a few years back. How old is the pump?
Old Jun 8, 2010 | 07:24 PM
Old Geezer's Avatar
Torture test.. Can you touch the pump after it quits?
If not, refer to Sweet71's post.
[Are you SURE the controller is working???]
Old Jun 8, 2010 | 10:47 PM
well the pump is basically new like it only has only about 800 miles on it but its 6 years old so not that new i guess and yes i can touch it t is only slightly warm and im pretty sure the controller is working because if i turn it all the way down the engine will stall. im debating about purchasing a rebuild kit for it though i wanna make sure that thats te problem
Old Jun 8, 2010 | 10:50 PM
also it doesnt seem like the pump quits because after the engine dies i can still hear the pump for a few seconds
Old Jun 9, 2010 | 07:29 AM
Old Geezer's Avatar
Tank vent working?
Old Jun 9, 2010 | 08:24 AM
dimetweaker's Avatar
Originally Posted by Old Geezer
Tank vent working?
thats what I was thunkin. Try it without a gas cap?
Old Jun 9, 2010 | 02:55 PM
well i noticed that tw days ago i hd it running for a good amount of time and i went to take the cap off and it instantly died as it released pressure
Old Jun 10, 2010 | 07:23 AM
Old Geezer's Avatar
Where is this pump mounted??
Old Jun 10, 2010 | 10:22 PM
below the tank lvel like before the wheel well like towards the front of the car
how would i be able to know if the tank vent is working
Old Jun 11, 2010 | 09:15 AM
Aeromotive Fuel Systems's Avatar
Closed ex-Sponsor Account
Purplepeopleeater:
There could be several things going on here. Here is quick set of questions that will point us in the right direction.
1. How are you getting the fuel out of the tank (sump tank or pickup tube).
2. If you are using a pickup tube what size?
3. What size line are you feeding the pump with?
4. Are you running a pre-filter, if so what brand and micron rating?
5. Are you running a post-filter, if so what brand and micron rating?
6. Have you checked your filters to make sure they are clean?
7. Is the tank vented, if so what size vent?
The answers to these questions will lead us to fixing your issue.
Old Jun 13, 2010 | 10:25 PM
well i am using the whole kit part number 17101 or 17102 not sure, the pump the pre filter(100 micron i think) yes i just cleaned it and i dont think that the tank is vented but im not sure all the lines are stock
i had it nstalled by quarter mile performance so i dont know all the specifics
Old Jun 14, 2010 | 11:42 PM
I APOLOGIZE FOR THE LACK OF INFO IT WAS MY STEPDADS car he just recently gave it to me
