Dual Walbro install pics
Old Jun 18, 2010 | 11:28 AM
91sbcamaro's Avatar
Default Dual Walbro install pics
Just wanted to post up some pics of my dual walbro setup. I couldn't find a Y fitting that would work and fit so I went with the T route. We will see how well it flows. I think when I switch to E85 I will have the Y out side of the fuel tank and just use bulkheads coming out of the tank for each pump.
Ill finish the wiring tonight and give them a test run while they are still out of the tank to make sure nothing leaks.
P.S. crappy cell phone pics
Old Jun 18, 2010 | 11:36 AM
quik01ss's Avatar
Are you going to be putting the bucket back on? I'm going to be doing the same going to duals for n20
Old Jun 18, 2010 | 12:08 PM
91sbcamaro's Avatar
Yes the bucket fits on there and then I will reinstall the filter socks so they are underneath the bucket. I just didn't snap a picture of it. I will get some more/better pictures tonight when I finish it.
For the bucket I cut out the bottom, cut a large hole on the flat side of the bucket and additional smaller holes on the curved site.
Old Jun 18, 2010 | 02:36 PM
waybad's Avatar
do you have to have a one way valve in between one of the pumps so it doesn't
pump fuel back through the other pump?
Old Jun 18, 2010 | 02:41 PM
No Juice's Avatar
Interested to see the rest of pics
nice work
Old Jun 18, 2010 | 02:47 PM
91sbcamaro's Avatar
The Walbro pumps have an internal check valve that will prevent any backflow.
Old Jun 18, 2010 | 02:59 PM
waybad's Avatar
Thank you!
Old Jun 19, 2010 | 11:37 AM
91sbcamaro's Avatar
Finished up the pump
Installed grommet:
Wired the pumps up:
One question I had was what if those heatshrinks leaked? Would their be a fire danger?
Old Jun 19, 2010 | 11:41 AM
ttranssam's Avatar
how long did it take you?
Old Jun 19, 2010 | 11:46 AM
KRAZY K 2000 TA's Avatar
why would it be a danger there is not one electrical connection sealed in the pump setup anyways.
Old Jun 19, 2010 | 02:47 PM
91sbcamaro's Avatar
Thats was my thought as well, I am confident about it just didnt know the whole electrical dynamics of it all.
It took me about 1 hour to pull the tank, another hour or so to pull the pump and disasemble, and hour to modify the bucket and install the dual pumps and another 30mins or so to solder and install the wiring(I have not run the hot wires from the alternator yet).
You could have it done in a day if you worked on it for 4-5 hours, I did research for a good 2-3 days before I even started so I knew exactly what needed to be done.
Old Jun 19, 2010 | 11:41 PM
01ssreda4's Avatar
I have seen stock pumps with exposed connections on both hot and ground inside fuel tanks before.
Old Jun 20, 2010 | 05:26 AM
NoTractionLS1's Avatar
I just saw a post not to long ago with exactly what you just said as well.
Old Jun 21, 2010 | 10:39 PM
01boydws6's Avatar
what did you do with the little hard plastic line???
Old Jun 22, 2010 | 09:36 AM
91sbcamaro's Avatar
I believe its sitting on my garage floor right now
Old Jun 22, 2010 | 04:14 PM
regorih383's Avatar
what are you going to use to turn on the second pump, or are you going to run them both together all the time?
Old Jun 22, 2010 | 04:25 PM
vetteboy99's Avatar
i lol'd at ur sig!!! Haaaaaaaaaaaaaaaahahahahahahahahahaaa.
Old Jun 22, 2010 | 07:51 PM
91sbcamaro's Avatar
1psi hobbs switch to run the second pump
