NEED HELP FAST. Stock feed for return question
Why not use the stock feed line as the stock return line as the return line?
Yes you can remove the stock fpr, it is held in place by the spring clip. Remove the spring clip and pry the fpr out then remove the spring clip. You will still need a fpr at the fuel rail. I would suggest an Aeromotive adjustable.
SO back to my original question why do people use the stock feed from the rear "T" as the return and not the stock return from there? I'll see if i can find a picture.
You are using the stock, hard feed line as the return - when you get back to the T-fitting, you are capping off the portion that would normally push the fuel to the filter (since the fuel is going in the opposite direction now), and just using the part that normally returned the fuel to the tank in the back?
Then yes, that should work. I went a different route by keeping the stock feed in place (I don't have huge HP that would make me want a larger feed line) and used the EVAP as my return - I just had to run a new line from the EVAP hard line in the back to the correct location on the top of the tank, but the line you will be using already goes to the correct place on the top of the tank, so it should be less work on your part.
The only reason that I could think people would use the feed line from the pump to the return block instead of the stock return line would be that the feed line is a little larger than the stock return.
On the feed I'm running a -12 to the pump and a -10 on the out side of the pump to the rails. The -10 feed is for the Magnafuel 4303 (pro tuner 750) I just ordered, the pump is able to support 2000hp N/A according to Magnafuel and 99% of the people I talked to that are running that pump run a -8 return. So in short on MOST cars any return bigger than -8 is just over kill. IMHO
The reason i used -10 line is because I got a stupid deal on my fittings and lines and it was going to cost the same. So why not? I have done so much to this car in the short time i have had it that i only want to do something once. So the fuel system will be competent to whatever i throw at the car. The only thing would i have to do is pull the bucket and add a third pump which is stupid easy because i set it up to accept a third one.
