98 z28 fpr
Does anyone know the location of the Fuel pressure regulator? b/c the dealership will sell you one for about $126, but they couldnt tell me where its located either. I keep hearing mixed opinions i.e its in the tank, or on top of the engine...im lost and im not even sure if thats whats causing my problem
Quick run down: sometime i have a hard start where i have to prime the key 3-5 time before it will fire up, also after i drive the car 5+ miles and turn it off when i start it again and start driving it stumbles and stumbles for a couple seconds and bam runs fine again. once i try to go WOT it stumbles then kicks like usual but it blows a quick puff of black smoke. the car has felt hesitant for a while now since the issue started but i cant pinpoint the problem. any suggestions?
In any case, your regulator is located in your tank in your fuel pump/sending unit module.
Put a gauge on it while trying to start the car. If you have to cycle the key several times before the pressure builds then the check valve in the pump is bad and allowing the fuel to travel back to the tank instead of holding fuel in the line. This is a common problem with Gm pumps.
Don't get a shitty fuel pressure guage from autozone either.. order a good piece online somewhere. You definitely don't want a knock off fpg if you are chasing a fuel issue.
well yesterday i removed the fuel rail for ***** and giggles just to see how easy it was, but everything back together it took about 35 min total. I jump in and try and start it and click...nothing i have power everywhere it just wont crank, so i took the battery to autozone and they gave me a new one i hooked it up today and click...same thing WTF am i missing here?
well i took the starter off, took it to autozone and had them test it and it was good, i got home and put it back on and the car fired right up!!! i didnt touch anything else!
you have a 98, just cut an access panel in the trunk area over the fuel pump and remove the fuel pump and bucket....... do a search on the access panel it is a VERY common mod to do , and easy.
