Do I have to run dual pumps
Are your numbers (550 and 350) at the wheels or at the crank? Those are very different numbers if at the wheels.
I'm currently planning a fuel system for my E85 LS3. It's making well over 700hp at the crank and I'm currently planning to use dual pumps, 10an feed and 8an return. I'm using an aeromotive regulator to step pressure down to carb pressure, but the pump volume is what's necessary.
Dual pumps seem to be good for 1000-1100hp at the crank.
Then I would think you would need dual pump.
550rw + 16% drivetrain loss + 33% higher fuel demands of E85 = 850hp of fuel demand.
Being that you are at altitude and can't actually make that power unless you drop down to sea level it might be fine on one pump.
**At least that is how I am estimating pump sizing for my setup**
