Need Help!!! Is there a certain method to splice a new injector plug into the harness
I had an injector pigtail break and i got a replacement from gm. What is the proper way to splice this in because theres only two wires and they are both white. Which wire goes where?
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Maybe you would rather pull the pins from the body
and reinsert them to the new shell? What broke?
If not, I'd orient the bodies the same, mark the wires
appropriately, solder & heatshrink.
Well the problem is that I have already had someone splice the new connector in and well i am just not sure that it was done right bc the piston on that particular cylinder lean out and burnt up so now i am rebuilding the motor! The part that broke was the black part so it wouldn't stay on all the way even with the clip in
Were the wires crimped in, soldered, connected some other way?
Personally, I would buy just a connector housing, and 2 new pins, then I would run the wires from the cars harness into it, and crimp the pins on like the original wires were without splices mid-wire. Injector wiring is a pulsewidth...one side see's ignition switched 12 volt power, the other side grounds through the PCM with a pulsewidth modulation that controls fuel...a shitty splice can affect the quality of that ground as well as the quality of the PWM signal, and could affect fuel.
I am not sure which side of the injector needs to see 12V (don't think it matters, but not sure)...however, if you look at the other 7 injectors, you will see they all have a pink wire...thats the power wire, the other wire will be different colors depending on the cylinder number. I would make the new one the same as the other 7 in that regard.
