what fuel cooler?
Some hp is lost due to high fuel temperature. If fuel is allowed to reach the boiling point it will turn to a vapor causing fluctuations in fuel pressure. Hot fuel evaporates at a higher rate not only causing pollution but creating more of a fuel smell.
The only way to minimize it is to do what GM does and return the fuel before it gets to the engine. I'd be curious to see if an engine could still reliably make 800+ hp and return fuel before the rails.
My shop said the air under the car is so turbulent that a fan or even position of the cooler wouldn't matter. Since I have no before/after fuel temp sensor I really have no idea how well it's cooling. A fan or air scoop might make it work better, but I haven't tried them.
