160lb Injectors - Bosch vs Ford
We are running around 900rwhp on 96# injectors (Low-Z) on an LS6 intake and stock pcm. HP Tuners tuned. 2004 Z06.
We are looking to go bigger and are considering the 160lb injectors. We are told the 160 Bosch might be a pain to tune, but the Ford ones will be better and are cheaper.
Any input?
Thanks
Any input?
Thanks
Any input?
Thanks
Any input?
Thanks
the 160 on our site is the new high impedance model that can run on the stock ecm. Any of those old f160's are low impedance and need a driver box to use with the stock ecu. be care full which ones you get.. 550 is a good price if they are the 845 white tops
hope this helps
