DIY twin pumps
Old Feb 7, 2011 | 03:55 PM
BLAKE 01 WS6's Avatar
Default DIY twin pumps
Just wanted to double check before I go any farther with this. As per the sticky above by mightymouse I can t two 255 lph pumps together inside the bucket in my tank and run the stock regulator lines and fuel rails? Just add the extra pump and they will both run all the time or put a Hobbs switch on the 2nd pump and it will only come on under boost. Of course I will have to add separate wireing for the 2nd pump? Bottom line I can keep my stock regulator lines and rails?
Old Feb 7, 2011 | 06:06 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Yes it will work, but running both pumps continuously can drastically increase idle fuel pressure.
Old Feb 8, 2011 | 12:12 PM
DopeFedLSX's Avatar
when i had twin pumps i had one on all the time and the second on a relay with my nitrous switch... i've since switched to a single Bosch 044 in tank pump... does all i need it to do
Old Feb 8, 2011 | 08:51 PM
when i looked that pump up it says it is an in line pump? also i think boosted cars require more fuel system than nitrous cars. on my h/c n2o my fueling was fine with the blower it wont keep up anymore.
has anyone mounted a adj regulator(boost referenced) near the tank instead of off of the rails?
Old Feb 8, 2011 | 09:08 PM
DopeFedLSX's Avatar
it is i altered my hanger to get it in the tank. had to buy a screw on fuel sock filter made for the 044. as well as a fitting to convert the outlet to barb for the feed hose.
i have pics if you need them and i can run the car far past the empty mark and it doesnt die out.
Old Feb 8, 2011 | 10:46 PM
nandos_z28's Avatar
Well what the hell ya waiting for?? Post em up and share! lol
Old Feb 9, 2011 | 08:12 PM
Lonnie i will try to give you a call tomorrow
Old Feb 9, 2011 | 09:03 PM
LS1TECH Sponsor
I'll be glad to help you out.
Old Feb 10, 2011 | 06:36 PM
man you got me in some trouble with that paypall
Old Feb 10, 2011 | 08:40 PM
LS1TECH Sponsor
She will get over it & you car will love you for it....
Old Feb 11, 2011 | 06:20 AM
I will get it done today around lunch, I have had to work alot
Old Feb 14, 2011 | 09:44 AM
Wife put the paypal through lastnight
Old Feb 14, 2011 | 09:55 AM
LS1TECH Sponsor
Thanks for your business.
We will get you taken care of.
Old Feb 14, 2011 | 07:47 PM
Thank you now i wont be worried about my fuel system keeping up your dual pumps and the 80lb injectors are more than enough for what I need right now.
Old Feb 18, 2011 | 09:16 AM
whats the eta?
Old Feb 18, 2011 | 06:23 PM
LS1TECH Sponsor
Kit should ship in approx 1 week. New sender came in today.
Old Feb 28, 2011 | 04:47 PM
Lonnie give me some good news.....
Old Feb 28, 2011 | 07:05 PM
LS1TECH Sponsor
It is finished & shipping tomorrow.
Thanks for your patience.
Old Mar 1, 2011 | 10:42 AM
Whoo hoo thanks
Old Mar 3, 2011 | 09:23 AM
Can you email me some tracking info? sorry man I am dying to get this project finished so I can enjoy this car again. Also I wanna make sure the wifey is here for delivery.
