FAST 42 same as FMS 42 Green top?
^ That's what I'm wondering. I got a KILLER deal on my 42#-ers.
I've heard that the Greens are rated at only 43psi fuel pressure, but will be closer to 46#/hr or so when run at 58psi in our cars. Just wondering if it's ok to run them past their rating.
I've got as set of Racetronix 42s that I am looking to sell. 180 shipped if anybody is interested.
Here are the specs:
Weight: 91.00GM
Brands: Racetronix_
Manufacturers : Standard Motor Products
Stock: No
Model: 621031
Categories: Fuel Injectors - High Impedance
Manufacturer P/N: FJ-SM-12S
Static Flow lb/hr (n-Heptane): 42.29
Static Flow Tolerance +/-%: 4%
Dynamic Flow (mg/pulse): 9.96
Dynamic Flow Tolerance +/-%: 6%
Coil Resistance Ohms: 15.9
Coil Resistance Tolerance +/- Ohms: .35
Spray Pattern: Tri-Cone
Connector Type: Minitimer (Bosch EV1)
O-ring Type: Viton
E85 Compatible: Yes
Methanol Compatible: Yes
Here are the specs:
Weight: 91.00GM
Brands: Racetronix_
Stock: No
Model: 621031
O-ring Type: Viton
E85 Compatible: Yes
