160lb injectors, high vs low impedance
Sigh. No one ever said they've had problems with them. Once again. THE ISSUE IS FIC AND OTHERS CLAIM THAT INJECTOR DYNAMICS SELLS THE EXACT SAME PRODUCT, JUST MORE EXPENSIVE this is NOT TRUE. The product that ID sells is an injector made by Bosch. Bought from Bosch. Those are the only similarities between the ID injectors and the other vendors.
Well, technically not the same. Neither FIC or ID manufacture the injectors, nor to they do ANYTHING that physically alters them. All they do is buy a batch, flow them (Not goig into the whole dynamic vs static debate) and group injectors based on similarities. (Caused by production variances from the OEM, who in fact built all of them.)
If you are happy with the wide ( and well documented) range of flows from Bosch, then by all means, buy injectors from brand X. Injector Dynamics caters to more discerning customer and tuners who know what they're doing.
More misinformation. The injectors ARE modified. They are serialized and ran on a flow bench. Then they are matched together. The other guys don't touch the injector, they run a group of them into graduated cylinders and then "match" them that way.
Running an injector on a flow bench is not modifying it. It simply helps in determining the characterisitcs of that specific injector. Again, not a modification.
Guess when it comes down to it, a serious tuner will rely on EGT temps and AF ratios as the primary indicator of how an injector is performing. Process Output data seems to be the most importat factor in getting desired results.
Please defined your use of the term "Serialized". Do you mean a specific serial number is added to them? Just want to clarify if that is what you define as modifying an injector.
how stupid are we guys.. We have been buying unserialized injectors. ****, no wonder i can only go 10.3 with perfect drivabilaty. I wish i knew about this serilization, I would have shelled out the extra 500 for that in a heartbeat. I'm saving up so for chrismas I can get me some. And how do you know what everyone else does? Stop it already.
I guess reading and spelling isn't in the curriculum over there in NY, is it sir? How about some spell check? I'm not going to continue to argue with you over and over like an insane person. You bought inferior injectors and are not only proud of it, you are quite smug about it. Congratulations.
Nice try, dip-****. This is 6th grade reading comprehension. I spent 6 years in the Air Force, so spare me the "I'm defending you" bullshit. I know you're done, because I'm so far ahead of you both intellectually and grammatically. Have a nice day, sir.
And buy the way air force man why dont you own american cars? all riceburners. Figures
#33
Thanks for the input. Guess I will stand by and wait. Until then, it seems that each vendor tries to sell batches of injectors which they group together by decreasing variances.
I have yet to see, or understand, how any vendor would have more resources to control PRODUCTION variance more than the OEM.
All what the vendors are doing (until shown otherwise) is test the injectors and group them based on variances. No physical change (Other than stamping a serial number) is being done. That is why they both tout the importance of their matching process. (Be it static or dynamic) Ultimately, you are paying a premium for a different (Maybe better, I don't know) form of matching.
#34
Having a 10 second RX7 and a car running over 190mph, you of all people should see the value of perfectly matched injectors. It's great that the brand "X" injectors flow "X" amount at 80% duty cycle, but what about idle? What about the rest of the entire RPM band?
they all idle perfect, they all drive perfect, the methenol cars the egt's are always good across the range of cylinders or rotors,
i have had all the methenol and E85 ones on my flow bench to check them and they are always spot on.
this dynamic flowing stuff only came around in the last year or so, before that was everyone getting second rate injectors?? no you just worked with what you had so why should it be any different now?
#35
here is a pic for you, 2 bosch and 2 ID's, you tell me which ones are which?
![](https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash2/73604_451897914153_534289153_5090274_2211819_n.jpg)
#36
I would say its the 2 with the serialization done by the injector dynamics Hewlett-Packard 5710-A dual-column gas chromatograph with flame analyzation detectors.
#37
If you knew what you were talking about, you would know that the 1600's and 2000's have a different type of pintle, which does not get modified in the same way that the others are. They are still batched and matched together just the same.
#38
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#39
I'm confused at this statement. Are you saying you can't tell the difference between perfectly matched injectors and stock injectors which are only matched at their peak flow rates? You're kidding me, right?
Well, to be honest most ECU's couldn't do anything with the data that Injector Dynamics has anyway, so it would have been for nothing. As ECU technology increases, so does the other technology. To your point, cars used to run on carburetors, now they are direct injected. Are you saying that since we had old technology, there's no real benefit to using new technology? The reason people "worked with what they had" was because they had no choice. But, I guess you're right. Let's get rid of supercars because they are new technology and we don't need it; we got by just fine before that. Corvette ZR-1's are stupid, new technology.![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
SO you are saying that unless you use a injector dynamics injector, one that is matched this special way, that the tunes will be inferior or impossible?
so heres the question, why does GM use a out of the box injector and run them in their flagship ZR1 and Cady CTSV. You would think that the engineers at gm would insist on using these special magic serialized injectors from ID. So would Mercedes AMG And Ferrari. Why would they buy inferior Bosch injectors when they can get ID's. If they won't buy them they must know that all this hype is something that ID made up. ALL I CAN SAY IS THAT THEY and YOU ARE NOT FOOLING ANYONE. They are just trying to justify why they cost twice as much!!! A good tuner can tune a car perfectly with any good set of injectors. I wish some would chime in here, Have a good night! And please don't answer back that my grammar is bad, no one is interested in that. They are interested in an honest answer
#40
just one question and then I'll be satisfied.
FYI, The new Noble M600 uses Injector Dynamics injectors as an OEM injector supplier.
