using stock feed line as return ???
doing my fuel setup now for the turbo car, i believe i have everything figured out, does anyone make a fitting to go from the stock feed line mounted on the frame right there to a -6?????? an or push-loc is fine....part # or link would be very helpful because im stuck against a wall right now!
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Or you can cut the metal tip out of the factory fuel to rail lines. Squeeze the end into your -6an and put a small worm gear on the end.
Ive done this to two cars and it works fine.
Did you remember to pop the factory fuel return out of the tank.
Ill run and take a picture..
i cut apart the stock fuel line too and pressed the stock fitting into a -6 line but it is scary to me, i bought a fitting from a local place, fitting was made by russell, said -6an to ls1,lt1,lt4 pressure side....this fitting did not work!
doing my fuel setup now for the turbo car, i believe i have everything figured out, does anyone make a fitting to go from the stock feed line mounted on the frame right there to a -6?????? an or push-loc is fine....part # or link would be very helpful because im stuck against a wall right now! ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
http://www.summitracing.com/parts/RUS-640853/
![](http://static.summitracing.com/global/images/prod/norm/rus-640853_w_m.jpg)
You have a return, however, it's way in the back. LS1 factory fuel rails are returnless, the system is not.
If you can use a pushlock fitting, summit racing has these.
thats the fitting i had, turns out all i had to do is put a little oil on the line to get it to press into the fitting, then it snapped right on, thanks for the help fellas'
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
