Race gas or octane boost?
Any benefits from one to another? I need to raise octane(11:3:1 comp) but don't know which way would be best? I was thinking use 94, and splash a gallon or two of race gas unleaded 100 or so. My other option would be use a quart of additive to raise octane. Any insight??
i'm running 11.3:1 right now... 93 octane and not getting any KR (though my car's got some other *stuff* done to it so my timing is only 25*)
But as mentioned... if it's a choice between one or the other... use race gas... octane booster is the biggest scam in recent automotive history! (as mentioned... a point is a 10th of an octane ... also it'll leave a red tinge on your spark plugs after many uses... and i've heard it can be bad for the O2s)
Originally Posted by BigPlanTransAm
how much more heat does it produce? when should i start worrying about detonation/cooling system?
I had no detonation at all with 22 psi boost when using Torco 104 where I could only run 18 psi with 93 or 93 mixed with store bought fuel addatives.
