Walbro 400 lph Fuel Pump
LS1TECH Sponsor
98 is not same as 99-02
This pump will not fit the 99-02 bucket w/o mods.
This pump will not function properly with the factory regulator in the 99-02 system.
We are working on a system solution expected this summer.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
416LPH E85 Certified HP Fuel Pump
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
We will post dimensions for these pumps in our web store shortly.
Thanks.
Thanks.
__________________
>WEB SITE<
>WEB SITE<
Well i guess your webstore is not working. i keep getting an error message. I need some info on this pump. is it available for the 2005 gto yet? is an aftermarket regulator still going to be needed? and a return.
also do you have a hot wire kit for the 2005 gto. i am in need of one asap.
LS1TECH Sponsor
It is working now.
We do not plan on introducing any new products for this vehicle platform. Please contact Lonnie's Performance. Lonnie should be able to offer you a custom solution using our components.
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
To run a FMFPR you will need to add a -6 return line regardless.
__________________
>WEB SITE<
>WEB SITE<
LS1TECH Sponsor
And chickens can fly if you use a big enough sling shot.
__________________
>WEB SITE<
>WEB SITE<
#38
LS1TECH Sponsor
Yes it can under WOT for short periods of time.
__________________
>WEB SITE<
>WEB SITE<
#40
LS1TECH Sponsor
That depends on the motor's BSFC, max fuel pressure and supply voltage????
__________________
>WEB SITE<
>WEB SITE<
