How do I know when I need a fuel pressure regulator?
I'm installing 42# fuel injectors for my 232/240 cam. Only have the stock regulator. At what point would I need an adjustable regulator?
I'm guessing you have an LT1 car....
In that case, I recommend one as you can easily tweak your idle/part throttle mixtures to make the ECM happy. You can get your fuel trims closer before you start tuning the ECM. There are direct fit ones for this application that take only minutes to swap out.
PM me with what you recommend. Thanx.
