whats the best fuel pump for pushing 80# injectors to 1000 hp?
Old 10-12-2011, 11:38 AM
96s-10ss's Avatar
Default whats the best fuel pump for pushing 80# injectors to 1000 hp?
looking to get a fuel pump for my new setup. going to be shooting for 1000 hp turbo. what are you guys running?
Old 10-12-2011, 11:53 AM
HydroStream6's Avatar
Twin Walbros here. 1000hp at the motor on E85 no issues.
Old 10-12-2011, 03:14 PM
SS-ROB's Avatar
I would give http://www.lonniesperformance.com/ a call!!
I am running a setup from him that is flawless!!!
Old 10-12-2011, 03:36 PM
FasTimeSS's Avatar
1000 to the wheels would be extremely sketchy on 80# injectors
Old 10-12-2011, 07:23 PM
93formto98T/A's Avatar
x2. 80lbers could be pushed to 1Krwhp on gas but not safely if at all on e85. When designing a fuel system on an FI build, you need to overestimate your fuel requirements and "overbuild" your fuel system. Ideally you would have either one big magnafuel 4301 or twin walbros or bosche in tank pumps, all large ID braided lines, boost referenced FPR, and 96# injectors. Not a good idea to rely on an underbuilt fuel system to keep up at 1Krwhp+. Think of how much you have invested in your drivetrain...is it really worth it to jeopardize everything?
Old 10-12-2011, 08:09 PM
buick_lsx's Avatar
How far will 60's or 80's take you on gas?
Old 10-13-2011, 02:02 AM
96s-10ss's Avatar
i will be running gas. what is your twin walbro setup hydro?
Old 10-13-2011, 07:58 AM
123quattro's Avatar
Twin walbros with a Hobbs switch bringing the second pump on near atmosphere.
Old 10-13-2011, 08:00 AM
Closed ex-Sponsor Account
JHR Performance's Avatar
This. Lonnies products and customer service are second to none.
Zach
Old 10-13-2011, 09:23 AM
rotary1307cc's Avatar
Magnafuel 4301 or 4303
Old 10-13-2011, 10:03 AM
MIGHTYMOUSE's Avatar
twin walbros. proven results, proven reliability, hundreds cheaper than the alternatives.
i run 3 walbros and 96#ers
2 walbros will get you 1k crank hp no problem, **** even with 60# injectors you can do that
Old 10-13-2011, 12:04 PM
96s-10ss's Avatar
255s?
Old 10-13-2011, 12:08 PM
eviltwin_1987's Avatar
Magna fuel 4301, super reliable, no controller needed, one pump and your done
Old 10-13-2011, 01:25 PM
PAT-WS6's Avatar
**** u cant argue with that, but what was your inj duty cycle with your 96s? when did you have the third pump coming on?
Old 10-13-2011, 01:39 PM
Restricted User
98Z28CobraKiller's Avatar
Mine were at 92-94% IDC on C16 with 80 psi of fuel pressure.
Old 10-13-2011, 01:43 PM
I need a gauge for that
Atomic's Avatar
What do you guys think about dual denso 1020s?
Old 10-13-2011, 03:09 PM
PAT-WS6's Avatar
on what injectors?
Old 10-13-2011, 05:12 PM
dont remember, at that level i was running 60's.
at the 1100RW hp level (1300 crank??) i am in the 90% dc range on the 96s
Old 10-13-2011, 05:30 PM
trav-tech's Avatar
what pumps were you running that still flow good up at 80psi? 044's? Cuz i know walbro's will not flow anything after their pushed much over 65psi or so.
my 60#'s are 95% duty cycle @700whp base fuel pressure set @45psi then you add 16psi of boost and your running 61psi of fuel psi getting close to the flow limit of the twin walbro pumps. im switching to 80#'s very soon got them just waiting to go it and get retuned.
Old 10-13-2011, 06:34 PM
I made 852 to the tires (manual) with 60s and two walbros.
60 psi base pressure and 14v to the pumps
Quick Reply: whats the best fuel pump for pushing 80# injectors to 1000 hp?
