View Poll Results: Whats the issue
Fuel pump
3
75.00%
Fuel regulator
1
25.00%
Fuel filter
1
25.00%
other...
0
0%
could be alternator related
1
25.00%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
Ok whats my fueling issue...???
Well 1998 formula loses power after 4k and pops like its lean. So i threw a guage on it and its at like 58psi during idle but if i stab the throttle and bring it past 4k or so the pressure drops quite a bit like down to roughly 15psi i dont really want to hold it there with the TB blade half open cause i dont want to lean it out bad.
So whats my issue? Fuel filter, fuel regulator, fuel pump anything else...?
I have been having a slight overcharging issue with my alternator when it is cold if that makes a difference but that clears up quickly. I doubt its the filter cause i replaced it about 10k ago and this problem came about pretty suddenly but ill throw a new one in there just for good maintenance.
why do you say the pump and not the regulator? Just wondering. I Would it be a good idea to put a new regulator in it while im in there or no?
yeah it will be the trapdoor method for sure since its already been cut when i bought the car. I also should have said i ran out of gas about a week or so ago due to my gauge being off if that would effect anything.
The regulator caps pressure, that's it. Pressure is normal until you demand a reasonable amount of fuel, that means the supply line is running dry because the pump cannot keep up.
