Are 42's big enough
Old Jan 13, 2012 | 06:26 PM
Swaie's Avatar
Default Are 42's big enough
I have some Ford 42's. I'm planning to run 6-10psi on my stock block with a 72mm turbo on a z06 cam and springs. Will that be enough injector?
Old Jan 13, 2012 | 07:44 PM
tomz28's Avatar
No you want 60s and if you plan on making more power down the road go 80+lbs it would save you time and money down the road. Im on my tried set of injectors lol
And the mods will be moving this thread for sure lol
Old Jan 13, 2012 | 10:22 PM
NightmareTA's Avatar
Def not enough injector. Go with 60's at least like tomz28 said. I havn't bought mine yet, but I am torn between 60's or 80's. Planning on 550 to 600 RWHP, so 60's may be on the edge. You can always tune down on a bigger injector to an extent. You can't tune up on an injector thats maxxed out though. Just keep that in mind.
Old Jan 13, 2012 | 11:06 PM
WS6HUMMER's Avatar
I have some for sale in my sig, they are low impedance though so you will need a driver. There are advantages of having low impedance injectors & if you ever wanna go really big you will most likely be buying low impedance injectors. The reason bigger injectors are usually low impedance is that they can open a lot faster.
Check out this link, its specifically refers to 60# injectors, & mine are cleaned & flow checked.
http://www.acceleronics.com/faq.htm#1
Old Jan 14, 2012 | 09:08 AM
sho-me speed's Avatar
Closed ex-Sponsor Account
42lbers will get you in the 550-600 range. With the mods you listed above and the boost level you are stating you will be close. I would look at upgrading to the 60's as stated above if you ever plan on upping the boost.
Old Jan 15, 2012 | 12:16 PM
pdasterly's Avatar
my 42's(bosch green top) stopped at 475rwhp boosted
Old Jan 15, 2012 | 07:58 PM
tomz28's Avatar
110% idc 625rwhp on 42s
Old Jan 15, 2012 | 08:01 PM
WS6HUMMER's Avatar
The safe zone is anything under 88% IDC if I remember correctly. 110% means you need to be shopping for bigger injectors.
Old Jan 15, 2012 | 08:06 PM
Louis's Avatar
What fuel system? Stock system, 500 rwhp max. Return style 550.
Old Jan 15, 2012 | 08:11 PM
tomz28's Avatar
No joke and that was with twin pumps return style
Old Jan 15, 2012 | 08:12 PM
tomz28's Avatar
That was a long time ago lol I have 80s for now
Old Jan 15, 2012 | 08:26 PM
WS6HUMMER's Avatar
Lol, yeah we all start somewhere, live & learn. Check out how far I pushed my 57's, by accident of course. Fortunately I realized that my car should not accelerate that fast & let out. Its still living with the motor GM blessed it with, this thing must have nine lives lol!
Check out the 3rd column down in blue.
Old Jan 15, 2012 | 08:38 PM
tomz28's Avatar
Lmao that is awesome
I went from 42 , than 60s now 80s and I might be switching to E85 been looking at 2200cc injectors lol
Old Jan 17, 2012 | 12:57 AM
Swaie's Avatar
I heard something like since they are ford injectors, they are rated with a lower fuel pressure. And since the Fbody fuel pressure is higher that makes the injectors flow more...is this making any sense? I was told that the injector could be used safely up to 500 hp. If they are the ford injectors?
Old Jan 17, 2012 | 01:05 AM
BigMilan312's Avatar
Go with 60's. Might as well just do 80's in case you wanna turn it up =]
Old Jan 17, 2012 | 07:09 AM
hellbents10's Avatar
LS1Tech Sponsor
They flow about 48lb/hr at 58psi, and I would only take them to 500rwhp max on a 6sp car and 475 on a auto.
Old Jan 17, 2012 | 07:10 AM
smokinHawk's Avatar
before the 60's came out everyone said you could go up to 600rwhp with the green tops.
i had them up to 700rwhp but running over 100% duty cycle so i switched to 96's
Old Jan 17, 2012 | 04:54 PM
wildcamaro's Avatar
I thought that when you run a ford injector on an ls1 they have higher rating than ford gives them due to the higher fuel pressure?
So 42# fords should be like 50# in an ls1 ( I don't know ratio just guessing)
Am I wrong?
Old Jan 17, 2012 | 04:58 PM
WS6HUMMER's Avatar
Am I wrong?
Injector flow is usually advertized @ 3 bar. Factory injectors may be different.
Old Jan 17, 2012 | 05:07 PM
warriorcustoms's Avatar
Im gonna run 42lb injectors on my N/A 396 LT motor Itll be around 550 at the flywheel & i have an adjustable regulator A turbo motor with the same power needs 52lb Theres a calculator thats got boosted or n/a & supercharged type choices Free download I dunno how to post a link lol Its virtual engine 2000 On an LT1 car ford injectors flow 5% more because of fuel pressure
