How to install racetronix fuel pump?
Ok so I think I might need a new fuel pump since mine the gauge is reading wrong and seems that when the car is off Im getting low fuel pressure on the lines
I believe I need this pump for my car
http://www.ws6project.com/user_stor/...x-fuel-system/
Also how hard is it to install, I want to see if their is a step by step or something so I can finish in 4 hours?
The fuel pump comes with full color instructions!
We also sell the fuel level senders:
http://www.racetronix.biz/itemdesc.a...LS-F99&eq=&Tp=
Installation time will differ based on experience and method used. We always recommend dropping the tanks and cleaning it thoroughly before installing a new pump.
Got my Racetronix kit for my 1998, would I run into the sending unit issues or is mine a totally different setup for sending the fuel level?
I didn't see a new sending unit for '98s on the website, just curious. Sorry to hijack.
Application specific.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
It took me longer to get the car up in the air and take the tire off than it did to install the new pump. The directions are step by step for your specific pump, and the kit came with EVERYTHING needed for the swap. Racetronix is the only way to go.
I got the whole kit from racetronix, just did the wiring, everything works great with the stock pump. Now it's time for the racetronix pump install.
Very complete kit, easy to do, I'm very impressed.
I think you can still run the pump without the hot wire, but i believe the racetronix pump likes a little hire voltage and thats what the hot wire kit does cause it connects to the alternator. its worth getting i got it with mine and it installs easy just follow the directions plus there are several write ups on here on how to install a racetronix fuel pump and hot wire kit
