what size injectors?
5.3 LM7
224/230 .538/.538 114+4
supporting cam mods(springs,pushrods, TC...)
Stock LS1 intake
P&P TB
MP T70
Intercooled
I plan on running the turbo at around 10Lbs until I get more supporting mods later on...
of course, a little room to grow would be nice also....
here is a injector calculator i found and with 93 gas you need a .65 bsfc and e85 you need a .8 -.91 bsfc hope this helps
http://www.injectorrx.com/sizing.html
Always buy the biggest injectors you can afford, that way you never have to upgrade them later.....
if i can get a 18.0 AFR idle out of my warmed up stock 4.8l car with an 80lb injector and a 15.0 cruise stumble free, what is the problem....
i have seen many friends buy 40s-50s-60s- and now 70s-80s
using the theory of only get the injector that you need.
cmon guys you are building 500+rwhp turbo cars, get a big ****** turbo, big fuel pump and huge *** injectors. you know you are gunna use it
