What fuel injectors for an LS1 intake with an LQ4 wiring harness?
I went to install my LS1 intake on my LQ4 in my 2nd gen camaro swap, and realized that the injectors out of the truck intake are to short for the LS1 intake. Is there an injector I can use that uses the same connector as the truck injector, or am I going to have to modify my truck harness to fit a car injector?
http://fuelinjectorconnection.com/sh...?productid=177
use ls1 injectors and this wire adapter is the cleanest way
the lq4 uses a 26 @ 58psi.. the stock 98 is 28.8 09-2000 is 26.6 2001 up is 28.8 so get pn 0280155890 that came in a 99-2000 which will be a good match as long as the lq is stock. we have them rebuilt for 189 a set.. new for 330 a set
i would solder when ever possible...easy to do and better connection... but thats just my opinion...ebay has connectors at pretty good prices. and besides its whatever you feel comfortable doing.
