Do you need check valves on dual fuel pump
Old 11-15-2013, 02:32 PM
turbotater1's Avatar
Default Do you need check valves on dual fuel pump
I am installing twin walbro 450 lph pumps. I am going to stage them running on one pump until X boost and then turn the second pump on.
With these pumps do I need a check valve on the second pump?
Thanxs
Old 11-15-2013, 03:27 PM
Unreal's Avatar
Should be built into the pumps.
Old 11-15-2013, 06:09 PM
is there a pic of what this check valve looks like to verify it has it or not?
Old 11-21-2013, 09:30 AM
realsquash's Avatar
You don't need to plumb in a check valve, no.
EDIT: Actually if you are connecting the jet pump in the bucket somehow you should run a check valve.
Andy
Old 11-28-2013, 11:33 AM
well i went ahead and added check valves . i did not want to risk having a problem turning the second pump on under boost. probably overkill but o'well.
Old 11-28-2013, 12:56 PM
realsquash's Avatar
That doesn't make any sense, there is a check valve in each pump and they work really well...
Old 11-29-2013, 04:12 AM
i did not see any type of check valve such as a O44 bosch has .
do you have a pic or documentation that shows that it has it?
just trying to have factual information for others who search for this information as i have installed mine now.
thanxs for your info
Old 11-29-2013, 08:23 AM
Old Geezer's Avatar
Maybe, ask the pump mfgr????
Old 11-29-2013, 03:29 PM
salemetro's Avatar
Personally, I would not worry about having installed the check valves. As long as flow restriction is negligible, you'll be fine. Maybe check combined flow of the pumps both WITH and WITHOUT the check valves installed, and make a decision. Not the most "scientific" approach, but should give you a good idea. Also...you could try pressurizing the whole system (minus check valves) with a gauge on the fuel rail to watch for rapid pressure loss when the key is "off", which would indicate the lack of a native check valve in the pumps.
Quick Reply: Do you need check valves on dual fuel pump
