Full Flow -8AN/-8AN In-tank twin setup, Holley Hi Ram, Walbro 450s
Old 06-04-2014, 11:58 AM
rorric's Avatar
Will e85 eat that aluminum 3 way connector since its not anodized??
Old 06-18-2014, 05:42 AM
blazinhd's Avatar
I read this and had to do it it was a good learning experience thanks for all the pictures like you said pictures speak 1000 words. The only problem I had is that I did have to cut the trap door cause when I put the tank back in the bulkhead 90°s were pushing up on the rear deck not sure what would be any difference
Old 06-20-2016, 09:34 PM
chrs1313's Avatar
Decided to make a direct drop in with Hotwire plug and play kit for 99-02...This might be a short run so get with me if intertested
https://ls1tech.com/forums/parts-cla...l#post19303255
Old 08-25-2016, 08:46 AM
chrs1313's Avatar
To the top
Old 10-27-2016, 11:47 PM
chrs1313's Avatar
To the top
Old 11-01-2016, 01:32 PM
TX98Z28's Avatar
I got a quick question for you, a little off topic but figured I'd ask. So will two 450's clear the opening on the top for the tank for a 98? Are the holes the same diameter for both the 98's and 99-02? I was planning to do either dual or triple 255's but hell if two 450's will clear and they are made for e85, win win!
Old 11-01-2016, 07:03 PM
chrs1313's Avatar
I do not have 100% confirmation they are same size, but I am pretty sure I have seen dual 450s in a 98 setup...
Maybe someone else can chime in
Old 11-01-2016, 11:03 PM
Slow94Formula's Avatar
I don't know if the tank opening is actually smaller, but I do know that 2 450's will fit in a steel tank. I had 2 450's side by side and they were a VERY tight squeeze. I'm not even sure how I got them in to be honest. They just all the sudden fell in. Another member on here has done 2 450's staggered and says those went in without issue. My most recent pump setup is 2 450's staggered and a 320 which all fit through the stock steel tank opening without even putting up a fight.
450s and a 320:
twin 450s only:
Old 11-02-2016, 08:38 AM
TX98Z28's Avatar
Thank you Sir, this answers all my questions regarding the 450's fitment. Damn and you added a 320 good god, bet you can pump the fuel out faster than the pump at the station can put it in!
Quick Reply: Full Flow -8AN/-8AN In-tank twin setup, Holley Hi Ram, Walbro 450s
