fluid dynamics experts please chime in
Bends aside, will one length of line of about 40 centimeters at 5/16" diameter, out of about 400 centimeters of line at 3/8" diameter still ONLY LIMIT maximum flow to the fuel rail to as much as can flow through the 5/16" section?
I'm using small line as an example but basically does the restriction along the line limit the total flow or does more of the fatter diameter line alleviate some of the restriction of flow that the small line created?
This stems from fuel pump outlets of 5/16" but people using -8AN and -10AN lines after this tiny point.
That is why an intank pump will flow 255lph of fuel thorough an opening less than 1/4" in dia, but your car would not have enough flow at the engine if you used a 1/4" fuel line. 1 inch of restrictive length at the pump outlet is proportional to the 150 inches of line to the front of the car.
It is all based on frictional losses. The higher velocity created by a smaller line will have more pressure drop than a larger line.
My biggest worry is the 1/4" return. I have seen many cars have high idle pressures due to a restrictive return. You should upgrade this if possible with -6 back to the tank.
