Fuel Injector Cleaning
These are very good prices for these products and I bought a case because each can was only $7.50 each.
I have four vehicles in my family and plan to perform this service every 30k-40k miles.
This service usually costs somewhere between $89-$149 per vehicle at a shop.
I picked up some connectors at Harbor Freight and did my first fuel injector cleaning today. My 2000 5.7L Trans Am was the first victim ;-). I did it first because GM made it very easy, the fuel rail has a schrader valve and the fuel pump relay is right there next to the radiator. All of this means, no tools required.
Anyway, I filled the container with cleaner, connected my air compressor to the tool, adjusted the pressure 5psi below the normal fuel rail pressure and started the car. It ran for about 10-15min, then stopped running when it ran out of cleaner.
BTW, I did not see any smoke coming out of the exhaust.
I then disconnected everything, installed the relay and it fired right up...the engine idled smoother and then I took her for A ride, my butt dyno detected a 10hp gain! ;-)
http://kalecoauto.com/index.php?main...&products_id=8
http://www.urbandictionary.com/defin...term=butt-dyno
Last edited by bgw70; May 21, 2017 at 01:02 PM. Reason: Non-sponsor live link removed
Do the cans say anything about the chemicals inside?
Most of the other carbon cleaning products use Naptha, which I understand will work on carbon much faster: https://ls1tech.com/forums/general-m...eafoam-vs.html
Kerosene should do a good job and cleaning up soft deposits, but I understand that it isn't very effective on the hard carbon deposits. (If it does make a dent, it would probably need to be used over and over and over to match one shot of Naptha for this type of deposit.)
Incidentally... Seafoam's MSDS now says that their ingredients are "proprietary hydrocarbons," or something like that - but I'll bet they are using mostly Naptha and Isopropyl, like they were before in their earlier documents...
I also never realized a gasoline combustion engine would run on kerosene. I knew jets and diesels will run kerosene.
I too looked at the MSDS and it shows >98% kerosene.
Polymer/Amine/Solvent Blend 2%
OTC Pro Inject-R-Kleen
That additional 2% of stuff must be an octane booster. I would definitely expect that if we took the car out for a drive (and put it under load) burning kerosene, it would knock like crazy.
Do the instructions also tell you to get the engine up to operating temperature before doing the treatment? I understand that elevating the temperature of the engine should also help burn the lower octane fuels, since we don't have the compression to do that for us. (Like in a diesel engine.)
I would like to try the product from GM, but will wait until I use this up! I still have 9 of 12 cans left.
I have four cars and have one more to go. Guess I could increase the frequency to every 10k miles to use it up faster! ;-)
Before I started, I measured the key on engine off and the initial fuel pressure would jump to 60psi then quickly bleed off to 15psi.
I then started the engine and the fuel pressure stayed at 60psi.
Turned engine off and repeated, same thing.
Then I ran the injector cleaner at about 55psi. Disconnected everything, turned the key on engine off again, fuel pressure jumped to 60psi, then went to 45psi and stopped. I let it set for about five minutes and no further bleed down!
I am very impressed with this fuel injector cleaner!
Now it's time for a test drive!
And let off the gas at the end...
And let off the gas at the end...Mine was a second gen body style...looked like the Porsche 944, I think!
Imagine an LS1 in that car! Wow, that would be badazz!
Okay, back to reality! ;-)
The first ingredient should be the greatest component. I saw a page where it's a by-product of the splitting of Naptha, so I would think it to be a close cousin.
