Fuel System Conversion on BBC and Injector Size
I have an open thread in the conversions/hybrids page of this forum. I am in the process of retrofitting an 0411 ECU to a GEN IV 72 Big Block Chevy. I am currently waiting on parts. While I wait I would like to build the fuel system on the car. I've upgraded pumps in already fuel injected cars and swapped injections on LSx's running pump gas but what I am looking to do here is a little different. Many of the threads online seem to have conflicting information as to what is do-able and I would like some advice specific to my application.
The engine is a 454 BBC with Iron Oval Port Heads. Will be running a Holley EFI Manifold 300-561. Engine is predicted to make between 500-550HP. I haven't chosen a fuel pump yet, I have a bunch of them in my basement. I will list what I've got an we can choose the best one lol. My goal here is a flex fuel tune... so 93 pump to E85. I know this is going to be different to tune because of the ecu I am using is not for a big block application and I am not looking to complicate things by going too large on the injectors but also looking for a size that will allow me to run E85 safely. I've seen recommendations online from 38lbs to 80lbs. The system is going to be a return style system with an adjustable fuel pressure regulator, so fuel can be pre-set at 43.1 psi and will remain there.
Also, what's a good, affordable source for a set of genuine injectors?
And if anyone knows of a thread where I can get a idea of how to route an out of tank pump correctly for a return style system, I would appreciate you posting the link. The tank was just replaced for a Carb Setup, and I am really trying to avoid having to replace it again for an in-tank pump.
Dan
Dan, take a look on the Aeromotive site, They have layouts for a system you are planning to use.
DG
If you've a 550hp engine, you need an injector that will support that, simple as that really.
Although surely it'd be easier to use a standalone ecu rather than trying to retrofit an OEM ecu ?
As for an external pump, as long as it is gravity fed with a good clean uninterupted supply of fuel with enough volume to keep the pump happy, it should be fine
The only pumps worth mentioning are 2 brand new Walbro GLS392 pumps I have. I also have a Mallory Adjustable fuel pressure regulator, part #4309 which is vacuum actuated. I guess since I have them it would be nice to use them if I can get away with it on E85? Also... would I need to run just one or both? and if so, Inline or side by side?
I am going to venture to say that they only way to accomplish this is with a sump... Any thoughts on a tanksinc?
Dan
Thanks,
Dan
