Need help finding fuel rails and injectors
Hi everybody I have an ls1 from a 99 z28 that I'm swapping to a third gen firebird the motor has 170k miles I've slightly rebuilt it. The motor has a high lift hot cam from the ws6 store pushrods and valve springs and I'm gonna use an slp loudmouth cat back on it. I just bought a fast 102mm intake and warr 102mm throttle body i would like some suggestions on what fuel rails to use and injectors . If possible id like to use the stock if there's adapters or something for the stock ls1 rails and injectors. If not some suggestions that arent too expensive would be appreciated thanks!
I think that intake requires aftermarket fuel rails or you can use Ls2 fuel rails.
To use the stock/ev1 injectors I think you also need a spacer kit due to the height of the injectors and where the rail bolts to the intake.
I have the msd Air Force intake with a 102 tb and the install is similar to the fast 102.
On both the installs few get away without grinding and some need to grind a little and some a lot.
yeah the throttle body is already on it had plenty of room..
do you know where to get the spacer for the injector?
Something like this. You can buy without the rail if you already have one.
https://m.summitracing.com/parts/fst-146021-kit
Also if you have a fuel rail already you don't need the one in that kit and I know they sell a adapter kit for much much cheaper without the rail. You can get a Ls2 fuel rail for about $100 used and save yourself some money.
As far as injectors, that is a question you would have to ask your tuner to see how close they are to being maxed out with your setup. Worse case scenario you can order gtp Bosch white injectors that will be plenty for ya. They flow about 40 lbs at 50 psi fuel pressure.
They came on supercharger gtp's and regal's
The injectors can be found at junk yards for cheap or you can order a set of 8 online for around $100.
