How to actuate BOV before a shift
Old Nov 21, 2017 | 11:10 AM
BigPlanTransAm's Avatar
Default How to actuate BOV before a shift
So I have an 02 TA with stock internals, rearmount single turbo, and 4L60e transmission. I only put down 450rwhp but I keep blowing third even with a built trans. I was wondering about the feasibility of somehow using the computer to trick the BOV to quickly open/close right before 2-3 to momentarily kill some engine power before that last shift. I'm ok with losing a little ET if it means I can keep using my existing transmission.
Old Nov 21, 2017 | 11:27 AM
BudRacing's Avatar
What are the torque management settings in the trans tune?
Old Nov 21, 2017 | 12:21 PM
smitty2919's Avatar
Surprised you are blowing a "build trans" with only 450. If you made something like 800 I could see that.
Like BudRacing said, look at TQ management numbers in the tune. I had my 03 Silverado 6.0L 2WD tuned and one thing that was adjusted was shift points and times to lessen the slippage. It resulted in quick and abrupt shifts on the 1-2 on anything over 1/2 throttle. I can drive around it, but needs to be adjusted so I can go WOT if needed and not have the trans slam into 2nd. All other shifts are quick and crisp.
Old Nov 21, 2017 | 12:31 PM
Ls1Ryan2002's Avatar
I'd hate to be that guy, but I'd keep the 60e going until it gives out and once that happens I'd go 80e or th400. I went through 3 60e's before I learned my lesson. I decided to go th400 and have had zero problems.
Old Nov 21, 2017 | 12:54 PM
01ssreda4's Avatar
Its something else, trans should hold that power. TM is a bandaid but should work in this instance. What are you breaking in the trans each time?
Old Nov 21, 2017 | 01:02 PM
If he's blowing 3rd, that's a direct gear. NO reduction or O/D. Forward clutch or mainshaft?
Old Nov 21, 2017 | 01:13 PM
01ssreda4's Avatar
I feel ya on broken 4l60Es, just had one repaired. I aint putting TM back in it though!!!
Old Nov 21, 2017 | 02:36 PM
rpturbo's Avatar
I have been down the 60e road and will be swapping to a 80e when the boost goes in. I have broke 3 N/A. The last build, was done by myself and friends. I bought good parts from a vendor on here, and it now is living. Truck puts down ~430ish and gets track beaten on. If you honestly have good parts, and the trans temps are down, you should not have a problem with the #'s you have. The problem is, getting a good builder.
Too many shops that are "local" are just jobber shops. They throw parts in and say it's "BUILT" and its really either not, or not assembled correctly. I know every clearance in my trans, and it was done to spec by the vendors numbers. I know my pressures, and my temps. It by no means is a crazy built unit, but it is a 5 pinion planet setup, with extra clutches, good steels, and a (MOST IMPORTANT) good tune.
Old Nov 21, 2017 | 02:53 PM
ddnspider's Avatar
https://ls1tech.com/forums/automatic...-hp-track.html
I blame the tune. This talks exactly what youre wanting to do to drop the power at the shift to keep the trans together.
Old Nov 21, 2017 | 03:27 PM
I haven't taken this one out yet but on previous ones I had taken them to a shop and stupidly didn't ask any questions so I don't know what exactly was broken before.--------------------------------------------------- As for the TQ settings, it shifts quite a bit harder than stock but again I'll have to ask a shop who can read it for me. This time I was staged and on the converter when I was told to back off for a minute before being allowed to restage. Previous times (yes multiple) were either similar situations or hotlapping.------------------------------------------------------ Because of this I think heat has a big part to play, and I do have a transcooler but I'm looking around for where I could fit a bigger one. On the subject of transcoolers, is there any reason not to have multiple coolers in line with each other for the purpose of fitting them in the car? My intercooler takes up most of the radiator and doesn't leave me much room to fit a large transcooler.-------------------------------------- The 4l80 has crossed my mind too but I really would like to take one more stab at the 60. That linked.--------------------------------- Also is this thread really in fueling and injection? I thought I posted to FI board, though maybe transmission would be better. I'm definitely checking out that other trans thread.
Last edited by BigPlanTransAm; Nov 21, 2017 at 03:34 PM. Reason: Used paragraphs+spacing but when I hit post it gets lumped into a big wall of text
Old Nov 23, 2017 | 09:59 AM
dlandsvZ28's Avatar
Ditto on local shops. My first 'Built' transmission by a local builder lasted less than 7k, never raced, behind a h/c, lts, 390 rwhp ls1. IMO all that was done was a simple rebuild and a shift kit. Never again will I trust local tranny shops.
Get a tranny from one of the vendors on this forum. IMO you will have much better luck and reliability.
That said, you have to know what causes it to break as well such as downshifting, etc. Some think you can drive an auto like a six speed. You can until it breaks.
Old Dec 2, 2017 | 08:51 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I blame the weak transmission design. Killing power to save your transmission is bullshit. The 4l60 has more weak points than most wet paper bags. They were fine as a 700r4 back in the 90's when nobody had more than 300hp at the wheels, but they are useless now.
Old Dec 3, 2017 | 07:18 AM
ddnspider's Avatar
Nobody's saying the 4l60e doesn't have weaknesses.....but plenty of people posted in that thread that they do something similar and keep the transmission alive and sacrifice little time at the drag strip.
